Results 1 to 12 of 12
    brozury
    29
    revo runs till it gets hot then it quits
    I think my 3.3 has seen better days.my revo will run fine for about 5 min. and then it quits and won't prime the fuel line.let it cool off and it will do the same thing.anybody have any advice?think i need new engine.I have flushed the 3.3,cleaned the carb.and adj. carb. to factory settings and still does the same thing.thinking of going with new lrp .30 bb with newera mount.
    Jul 2011
    S. Jersey
    782
    How many gallons are on that engine?
    Jato 3.3, Revo .28 JL Max, Nitro Stampede 3.3
    brozury
    29
    i've ran 4 gal. though it bought it used so really don't know.it ran great for a while the it was all down hill.one part after another!but now i've installed all new waterproof servos,optidrive,shift sensor,tunned pipe/header.so all thats left is the engine!whats another $110 maybe then it will run for awhile.
    Jul 2011
    S. Jersey
    782
    It's probably shot. You can get a new piston on sleeve for around $60 on eBay.
    Oct 2005
    South Florida
    19,234
    Quote Originally Posted by tats4u View Post
    If you run a good tune the engine should last 6-8 gallons... I've actually gone more but the performance was not there...
    You bought yours used....
    Definiately sounds like the piston and sleeve are worn to the point as they expand you don't have enough compression to keep the combustion cycle going...
    $60.00 on Ebay gets you a new piston, sleeve AND conrod. Just a thought.
    All Lives Matter
    brozury
    29
    thanks for the info. but the ez start is shot was wanting to go with tiger drive roto start or pull start.and the new 3.3 comes with pull start and new carb for $110 don't see where i can go wrong for $50 more bucks.
    think i got the best of the 3.3 when i put new tires/wheels on it.I put the big joes 4.0 on it.then it would barley pull itself.it should run fine with the big tires on it once i replace the 3.3 right???
    Grafenwoehr Germany
    1,302
    You might have to go I tooth lower on the pinion
    11,890
    Pinion? I must be behind the times.
    Grafenwoehr Germany
    1,302
    Lol well I ment clutch bell haha
    I musta been stuck in the electric section of my brain lol
    brozury
    29
    yeah i don't think changing the clutch bell will help the engine.its toast!
    double G do you think the 4.0 tires i have on it will hurt the new 3.3?i know it will put more of a load on the engine because there is more rotating mass,so therefore it takes more hp/torq to turn them.i have 3 sets of tires stock,hpi roadrages 3.8,and the 4.0 big joes.just want to get some advice so i don't prematurly damage my new engine!
    and i am running the stock clutch bell gear and 40t spur gear sometimes i put the 38t on it what do you suggest?
    Grafenwoehr Germany
    1,302
    I was talking about with ur new motor...
    Oct 2005
    South Florida
    19,234
    Big Joes = gearing change...
    All Lives Matter
