Results 1 to 7 of 7
Thread: EVX-2 w/ LVD
    Mass
    113
    Question EVX-2 w/ LVD
    So, was bashing yesterday and my LVD kicked on. Seemed kind of quick, so I went inside and checked the battery voltage. Both packs (2s) were at 3.8. Isn't this a little low for it to be going into half throttle mode? My VXL will run them down closer to 3.4 before LVD kicks in.
    Is there a way to adjust the threshold?
    Thanks in advance...
    RC Champion PowerToTheMaxx's Avatar
    Sep 2010
    Chicago, IL
    2,338
    Ehh, ya put it in NImh mode and buy a LVA?
    sometimes, with low c batteries, the voltage drops under throttle, and then comes back up when you take the load off. this is what triggered your LVC i think
    This parrot is NO MORE!!! This is an ex-parrot!!!
    Mass
    113
    Good point...they are traxxas 25c batteries so you may be on to something. Thanks.
    Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
    Sep 2010
    Chicago, IL
    2,338
    Ya, even my 65c trips the LVA when I nail it near the end of its cycle.
    1,350
    Quote Originally Posted by bigbadballard View Post
    What MAH are your 25C LiPo's?
    How much run time are you getting before the LVD kicks in?
    Mass
    113
    They are 5800mah 25c traxxas packs...probably get a good 20 minutes of trigger heavy bashing...
    1,350
    Yeah that seems a little short. Maybe the lower c rating is the cause.
    Are you balance charging them? Check the voltage on them when they are finished charging. A good 2s LiPo should take around 8.4 volts
