Results 1 to 10 of 10
    Jul 2012
    242
    Heat sink compound??
    It was suggested to me that I put heat sink compound in between my motor and sink. It transfers heat to the sink better.(so I've been told) I'm gonna do it, but has anyone else ever heard of, or done this? Thanx.
    Aug 2012
    11
    Not sure about rc applications but on computers you put a thermal heat compound in between the sink and cpu, same idea I suppose but idk about this
    Sent from my SCH-I535 using Tapatalk 2
    Jul 2012
    242
    My uncle is a fellow RC nut, and works with computer equipment everyday. His thinking was that the heat sink would not have as much potential to disperse heat without it. Ima give it a go. Caint hurt nothin I guess.
    Jun 2010
    Miami, Fl
    6,731
    That would work.
    Aug 2012
    Central NJ
    1,245
    Thermal compound is made to get a better contact between two surfaces at the micro level. If it requires anything more than a very thin coat the compound will actually act as an insulator and cause the heat to be even worse. Ive built hundreds of PCs and Im an electronics engineer and have seen more than one CPU in a PC get fried from this as well as IGBT power modules in large scale inverters. Same principles as soldering......the bigger the blob does not mean the better the job.
    Jul 2012
    242
    Yea. That's kinda how he explained it to me. Very thin coat. Nothing more. Thanx
    Davenport, Iowa Quad Cities
    2,471
    Someone once removed the heatsink off the stock esc and used a thermal compound and added a pc heatsink. There was a thread about it. He posted some pics.
    Jul 2012
    242
    Thanx dnuckles. I'll try to find the thread.
    2,471
    I woulda searched but had to leave. Hope you found it...
    12,611
    If you find it, could you please copy and paste it on this thread so we can all be reminded of how its done?
