Results 1 to 14 of 14
Thread: opinion needed
    Sep 2011
    Iowa City, Iowa, USA
    4,073
    opinion needed
    Im going to get aluminum axle carriers but which ones are the best? I was thinking gpm hr or gh. Im a hard basher so i need something durable. Also any opinion on hr sway bars?
    so cal
    9,244
    I have the gh carriers. Holding up great can't go wrong. Some have problems with the hr carries they have a round hole while the others are square and some have the pillow balls pulling through
    I also have the hr sway bar on my other merv. Helps alot in the corners obviously!
    RC Racer Beaz's Avatar
    Vic. Australia
    233
    My gh knuckles have held up to Hard Bashing..for say 7-8 months so far..and they be the square hole variety..I have pulled balls thru trx, rpm, but that's what I get doing cartwheels!!
    1/16 EREVO, 1/10 SUMMIT
    so cal
    9,244
    Sep 2011
    4,073
    Ok ill try the gh carriers. would you recommend sway bars on a dirt track?
    so cal
    9,244
    I don't know how great it would be in the dirt on a track. Bashing around it works fine . With the sway bar if you compress one wheel then the other and let go of one it holds the other wheel up a bit. If that makes sense
    Feb 2002
    7,945
    sawybars help handling, but limit articulation
    i would get gpm or gh.... hr is usually a fine company, but their knuckles have documented issues with quality control on the threads, 50/50 chance of being bad..... for the same price as the gpm or gh, that have little to no reported issues
    http://www.youtube.com/watch?v=3nhgfjrKi0o
    Jun 2004
    1,894
    Quote Originally Posted by Jimdog View Post
    They should help quite a bit on a dirt track, it will keep the truck more planted to the ground and it will not tend to roll over as much, the only draw back is that you loose some of the articulation but usually it doesn't matter unless you're bashing. I've always used sway bars in any vehicle I've raced or that I'm currently racing and I think most racers would suggest using them.
    ***You Build It ...I'll Jump It!!!*** OS .18 TZ; Trinity Pipe; HCR Titanium Skid Plates & Bumpers; Futaba S9450 Throttle Servo; Airtronics 94358Z Steering Servo; RPM A-arms & Knuckles; FOC; Lunsford Titanium Hinge Pins,Turnbuckles, Push Rods & Rocker Posts; New Era Roll Bar & Engine Mount; Proline Mashers on Velocity Rims.
    so cal
    9,244
    Have you seen the hr sway bars up close? They don't work like a true sway bar like on my s2000 or even my 1/8 scale buggy.
    With the hr on a track if you hit a bump that compresses both tires then the ground drops down on one side. That tire will hang in the air where a car with a conventional sway bar would lower the tire and have contact
    Sep 2011
    4,073
    So are there any sway bars that you would recommend?
    Feb 2002
    7,945
    the only ones made for the mini are the hr.... it isnt that they are bad, it is jsut they aren't the same as most
    so cal
    9,244
    For the track run wider offset rims and some good tires
    Sep 2011
    4,073
    What could i do about the sway bars if i got them?
    so cal
    9,244
    Run them! I have ran them bashing and they worked good
