Results 1 to 21 of 21
    Canada
    275
    Losi Ten T shocks
    What are the part Numbers for the Losi Ten T shocks that fit the Slash 4X4? The D8 part numbers are also welcome if anyone has those?
    Jun 2010
    Miami, Fl
    6,731
    you donīt need parts numbers just google them by the name.
    Canada
    275
    So there is only one Ten T shock? Are they the same length front and rear?
    Aug 2012
    How can i clean my slash 4x4 6808?
    7,173
    Losi Ten-T/ SCTE shocks are the same. Look for Fr/Rr sets of the shocks. They don't have a pn, just pulled off the trucks from chop shops.
    Losi Ten-T/ SCTE Shocks
    If you want to build your own like I did for not much more here are the part numbers. STRC has a handful of color choices. This is the list from my recent build.
    1 x LOSB2845 Losi Front & Rear Shock Shaft Set (4) (Ten-T) $9.25
    1 x LOSB2904 Losi Front & Rear Shock Plastics & Ball Set (4) (Ten-T) $6.39
    2 x LOSB2906 Losi Shock Rebuild Set (2) (Ten-T) $9.18
    1 x SPTSTLB2825R STRC CNC Machined Aluminum Front Shock Body Set (Red) (2) $13.49
    1 x SPTSTLB2826R STRC CNC Machined Aluminum Rear Shock Body Set (Red) (2) $15.49
    1 x SPTSTLB2904R STRC CNC Machined Aluminum Shock Cap Set (Red) (4) $17.99
    1 x LOSB2905 Losi Front & Rear Shock Boots (8) (Ten-T) $5.49
    Total $77.28
    I added the Red Aluminum Shock Caps. If you didn't buy those it would be $18 cheaper at < $60. Which still isnt bad for a set of good shocks.
    Here is the shock in red anodize.
    Hope this helps ya bud.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Canada
    275
    Why did you use STRC bodies and caps and not the Losi ones?
    7,173
    Quote Originally Posted by bruggar View Post
    Because STRC offers other choices of colors. Still the same basic shock. Plus you get to build them and put your wt of oil in there.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Davenport, Iowa Quad Cities
    2,470
    Thanks Digger. I'm going to look into doing that. My lhs can get 20% cheaper than those onlince prices. So That will be my next upgrade. Thanks for sharing...
    Canada
    275
    Quote Originally Posted by DiggerPede View Post
    What springs did you use?
    7,173
    Those are the stock springs for the shocks. They also offer silver ( softer ) & gold ( harder ) springs.
    Sent from my Samsung Galaxy S III ~ using Xparent Green Tapatalk 2
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Canada
    275
    Do you have the part #? It's not on the build sheet above.
    Jul 2012
    Sweden
    19
    Do you need something to mount them on the slash, i've read that the upper part must use some special kit?
    Which spring will be best for tracks with som fairly big jumps, the stock springs or can the losi springs used in the_jang setup be used with the ten-t shocks?
    Nov 2008
    Halifax County, Nova Scotia. Ca
    1,146
    Are the 10t shocks supposed to be the "bees knees' of shocks for the slash 4x4 or are they about par with the Big bores and prolines ? Thanks..
    Always in Trouble for trying to help out.
    7,173
    The p/n's for the springs. I just found the tuning kits below. I have an order I need to make here in the next couple of days. I'll prolly pick the Fr & Rr up for grins. Wouldnt hurt to have anyways i'm running thse shocks on my Digger & Sl4sh.
    1 x LOSB2962 - Losi Front and Rear Shock Spring Set (4) (Gold–Firm) (Ten-T) $6.39
    1 x LOSB2960 - Losi Front & Rear Shock Spring Set (4) (Silver/Soft) (Ten-T) $6.39
    Rr Spring Tuning Kit:
    1 x LOSB2963 - Losi Rear Shock Spring Tuning Set (8) $16.49
    Rear Set Includes:
    2.7 rate Red springs
    3.0 rate Orange springs
    3.3 rate Silver springs
    3.6 rate Green springs
    Fr Spring Tuning Kit:
    1 x LOSB2959 - Losi Front Shock Spring Tuning Set (8) $16.49
    Front Set Includes:
    3.9 rate Blue springs
    4.2 rate Black springs
    4.5 rate Purple springs
    Here's a littlle bit of info on 'effects of shock spring changes'.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    7,173
    Quote Originally Posted by snav View Post
    In the list above (( 2 x LOSB2906 Losi Shock Rebuild Set (2) (Ten-T) $9.18 )), this includes the shock bushing to install the shocks onto the tower. I believe you can use shoulder bolts to. I can confirm this for you if you'd like. I made my own bushings for my first install because I like using the Proline Universal Shock mounting kit for quick removal.
    Quote Originally Posted by madkawi650 View Post
    Depends on who you talk to. LOL I own the BBs, Proline Powerstrokes, & the Ten-T's ( one pulled direct from the truck, & one I built myself ). They are all good in their own way. The BB's are really nice and do an excellent job and are at a good cost. The Proline Powerstrokes are going to cost nearly 2x the cost of the BBs and Ten-Ts. They offer dual rate springs, that eat up bumps really well ( if you buy their tuning kit springs ). Kinda pricey IMHO, but I still like them. Out of both of these the Ten-T's offer a really nice plush ride. You really don't need a hard spring or thick oil in them. Probably someone that has the best knowledge on these shocks/ springs is 'thedreadedend'. He got me hooked on these suckers. I believe once you run then and tweak them to your liking you will see what we are talking about. Kinda hard to tell you what to put in your truck because everyone's trucks are setup different, lighter/ heavier, different terrains, and styles of driving.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Jul 2012
    Sweden
    19
    Thanks for the info, 2x rebuildkit ordered
    7,173
    Are you building the shocks or buying from the eBay chop shops?
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Jul 2012
    Sweden
    19
    ebay "chop shop"
    7,173
    ebay "chop shop"
    Awesome!! At least you will have some spare parts to rebuild your shocks if need be. BTW the stock shocks come with the black springs and 30wt oil.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Jul 2012
    Sweden
    19
    Good to know
    also ordered both spring tuning-kits.
    Only got 35 and 40wt oil home.. will try some new springs and standard oil
    7,173
    Great!!
    I'm running 40wt Fr & 45wt Rr on this truck with the black springs. I really need to pick that tuning kit up. I'd like to test the different spring rates myself. I've had good luck with the Silver, Black, & Golds so far. Those tuning kits should help you get more precise on how you want the truck to react. Losi has an awesome Shock oil set(s) to really tweak these puppies.
    LOSA5242 - Losi Silicone Shock Oil Six Pack (17.5,22.5,27.5,32.5,37.5,42.5wt) (2oz) $20.49
    LOSA5240 - Losi Silicone Shock Oil Six Pack (20,25,30,35,40,45wt) (2oz) $20.49
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
