Thread: Overheating
    Jul 2012
    Houston, Texas
    51
    Overheating
    If I have an ESC cooling fan and an aftermarket motor cooling fan, is there still a big risk of overheating the motor/ESC if I run the optional pinion gear that comes with the truck on the track?
    Maryland
    336
    I run an esc fan and a heatsink with custom fan on the motor with stock gearing. I can run an entire 5800mah 2s lipo pack through the truck with temps around 150-160 after about 35 min of hard running. 3s lipo is a different story... same setup I hit 180 and have to let it cool after less then 15 min.
    No Limit RC of Maryland
    RC Qualifier guardog's Avatar
    Nov 2011
    Pa
    735
    Always check temps and let it rest regardless of fans. I just melted the epoxy out of 2 stock vxl motors because I changed my pinion and was running 3S. Temp gun is a must
    Beatings will continue until compliance is gained
    uh oh.... that didn't sound good
