    Jul 2012
    Yakima, Washington
    1,440
    gearing questions
    want to go brushless and i was wondering what you need to change from stock brushed
    Alma, Michigan
    12,313
    That all depends on what you are changing it to.
    There is no such thing as magic gearing that works for everybody.
    The only thing that can tell you what gearing to get is a thermometer.
    Jul 2012
    Yakima, Washington
    1,440
    just want to run with stock tires and traxxas 1/16 brushless system
    Alma, Michigan
    12,313
    Stock is 23/28 pinion and 50 spur.
    Jul 2012
    Yakima, Washington
    1,440
    thanks i will have to get a thermometer but what kind do you use
    Alma, Michigan
    12,313
    I use a cheap-o harbor freight jobby:
    http://www.harborfreight.com/non-con...ter-93983.html
    84
    Stock Summit VXL gearing is 16 pinion and 50 spur.
    Alma, Michigan
    12,313
    Thanks for the correction.
    Even with that low of a gearing, you may need to go even lower... the bigger tires of the Summit create more heat.
    Jul 2012
    43
    I can vouch for that. I get a little warm sometimes on stock summit gearing, even though I cut open my body for more airflow.
