Page 1 of 2 12 LastLast
Results 1 to 40 of 41
    Aug 2012
    68
    MERV antenna length - Cut or Not to cut
    Hi All,
    I am rebuilding my MERV and have a seen some of the pics out there which have a very small antenna i.e. about 2"-3" fixed to receiver box. I think the idea is to have it covered by the body and not show it sticking out.
    I have a full length antenna and would like to know if I can cut it short.
    My questions are as follows:
    1. Does it affect the performance i.e. signal strenth or distance. If it is a problem than I dont want to cut it
    2. If cutting it short is OK then what is the right way to do it. I have a long wire sticking out of the receiver box, do I cut the wire also or just wrap it up into the box and stick the remaining part into the shortened antenna.
    3. Is there a step by step guide out there.
    Thanks
    Feb 2002
    5,076
    do not cut the wire
    82
    the short antenna's are for the 2.4ghz radio's and the long one are from the 27mhz radio's . i dont know if making the antenna tube shorter will affect the performance
    Aug 2012
    68
    I have the 2.4ghz radio.
    Noted that I cannot cut the wire.
    Can you cut the antenna down to a smaller size. If yes, what is recommended size.
    Also should I wrap the wire and put it inside the recever box. Suggestions???
    Jun 2010
    Lancaster PA....... NO i'm not Amish
    321
    I run my 2.4 with just the metal end exposed in the tube and the rest of the wire tucked inside the radio box. never have range issues.
    MERV VXL + Rally VXL + Stampede Xl5
    Rotterdam, Netherlands
    7,608
    You can make an antenna tube with a length so that it fits right under the body and put the end of the antenna wire in it and put what is left of the wire in the receiver box.
    Oct 2010
    Montreal, Canada
    416
    Don't cut the 2.4 ghz wire. The top of the antenna has some metal thing that shouldn't be cut. Coil up the rest of the wire in the receiver box and use the short antenna tubing. It's something you don't mess with and the small antenna hidden under the body looks nicer
    HPI Vorza | Traxxas Summit | 1/16 Traxxas E-Revo
    7,263
    i had mine (2.4ghz) cut accidentally right at the end of the metal tube by flipping over without the lid but i found a sollution to regaine its signal back.
    humay has left the building, peace.
    Rotterdam Hoogvliet NL
    886
    you can go short and just under the body shell
    the rest like peter is saying you put into the rx box
    but dont cut the wire
    lisen to Peter his advise
    Xtreme has no limiits
    Australia
    387
    I would just get the 2.4 ghz
    899
    But hammer, the 2.4 on the brushed slash and merv has the long antenna on the rx.
    Has anyone with the brushed version with the long Antenna had any reception problems when putting the excess black wire in the rx box and shortening the blue tube to hide under the body?
    Oops I meant to say, "the 2.4ghz comes with the brushed merv, but it also comes with the long antenna"
    Does anyone know why the brushed merv has the long antenna when the brushless merv does not? Both are 2.4ghz
    SE Texas
    1,178
    Even the new vxl brushless has the long antenna tube.
    The key word here is "tube"
    YES...you can cut the tube down shorter...but DO NOT alter the length of the antenna itself.
    As was mentioned above...just coil the excess wire up inside the receiver box.
    "Dude,I almost had you"
    R.I.P Paul Walker
    899
    That's interesting. My merv vxl I got 2 yrs ago had a short tube. Wonder why they made the switch?
    Anyways, thx for replying.
    Apr 2013
    19
    Hi
    As discussed in other posts, Traxxas is now shipping a 71074 model, as opposed to the older 7107 model.
    As strange as it may seems, the old 7107 model came with TQi controller and short antenna. The new 71074 model comes with a TQ (not TQi) controller and a long antenna, which can be shortened with no problem, though.
    I have both the 7107 and 71074 model and the 71074 model has a TQ reciever also.
    899
    Can any experts out there guess why traxxas would elongate the tube on a newer merv model, knowing that 10/10 people would prefer not to have a goofy tube sticking out of their roof??
    Apr 2013
    85
    I just asked this in reply to another post and my reply was deleted. As much as this has been discussed one would hope Traxxas is listening
    263
    Quote Originally Posted by varunaX View Post
    I think they need the long antenna for range. We cut my brothers tube short and it isn't much better than a 27 MHz radio
    Apr 2013
    19
    RZSmerv, interesting note you have, saying that your post was deleted.
    I had a similar post regarding the 7107/71074 model including an answer from Traxxas support just stating that the long antenna was needed for range on the new 71074 model. The post got many replies, as many others had the same experience of buying a new Traxxas model and got a TQ controller and a long antenna.
    The post got deleted. I even have a post where I ask where my post has gone.
    Were they censored away?
    Apr 2013
    85
    my son's car with the short antenna can go so far away that I can not see it - so I dont think its a range issue - at least not with the tqi
    899
    Quote Originally Posted by RZSmerv View Post
    Ditto.
    Makes you wonder even more why they'd change something that no one ever complained about.
    Other than the user 2 posts up (which is VERY interesting to say the least), has anyone else had success cutting their tube and experiencing 'tqi like' unlimited range?
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,427
    Guys it is fairly obvious the new radio is not the TQi. Why they went to the new radio we can only guess but clearly it is not the same as the TQi and apparently it needs the longer receiver antenna to keep the range.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    899
    i think thats where we are confused though Dad. Both the TQ and the TQi are '2.4ghz'. Why would the range differ for both? Why/how can the TQi with the SMALLER antenna provide greater range than that with the longer antenna?
    Alma, Michigan
    12,311
    There is a lot more to range than just antenna length.
    Jan 2008
    Sugar Hill Ga.
    8,387
    How long is the antenna with the TQ 3 channel anyone have a measurement?
    I have 3 TQI (#6518) receivers that the antenna measures 10 Ĺ inches. Curious as to the difference in length.
    As with any receiver if I want the best possible range I leave the tube long and use all the antenna I can above the body. If Iím just bashing and donít need all the range I curl the antenna up inside the rx box and use a short tube.
    899
    Quote Originally Posted by wfburton159 View Post
    These results corroborate mine as well.
    As mentioned by others, it is clear the 'newer' 2.4ghz rx/tx is a whole nother 'beast' than the phenomenal system before it.
    SE Texas
    1,178
    Makes me like my Flysky GT3C even more.
    R.I.P Paul Walker
    7,263
    I still have my 2218 receiver with antenna wire cut from flipping over. I have two and both wires are cut.
    Reno, NV
    792
    Quote Originally Posted by hammertron2000 View Post
    Agreed. TQi all the way! Note: Be very very careful with the wire. It can break easily. Put the wire to where it just fills the tube (the short one) and cap that. Done.
    899
    Naw that's not a very good argument (unless your rich). . When you are buying a 300$+ for a Brushless kit, you shouldn't have to spend an additonal 60$ for the rx/tx that came with the model 2 yrs ago.
    Alma, Michigan
    12,311
    I am still hesitant to recommend the TQi to anyone... it seems there are some electrical gremlins that are still being worked out if you visit the radio section of this forum.
    Riverton Utah
    4,490
    I'm only seeing threads in which people dropped them, etc.
    Summit Rustler Sl2sh TMaxx Pnde Slayer Sl4sh
    Alma, Michigan
    12,311
    Quite a few have gotten deleted due to the thread becoming a Traxxas bash fest and not in a good way.
    Here are some that I found in just the first two pages:
    http://traxxas.com/forums/showthread...g-during-a-run.
    http://traxxas.com/forums/showthread...es-not-turn-on
    http://traxxas.com/forums/showthread...irmware-2.0.44
    http://traxxas.com/forums/showthread...83278-TQI-Dead......
  33. #33
    Paved Paradise Florida
    124
    Thumbs up
    hmmm. makes me wonder about the new radios being shipped, they dropped the -i and added a huge antenna to the receiver. perhaps this is in response to TQi issues. overall, the percentage is likely very low, but on a huge number of units sold that small percent becomes a large enough number to call for a design update.
    perhaps the 71074 is in fact a blessing in its stripped down disguise. I'll blame the MSRP increase on the lousy economy we got here in the states.
    MERV - 3S 23/50
    Revo 3.3 - stock
  34. #34
    Nov 2014
    10
    Hello,
    1/16 Slash 4x4 has run OK for 1 week with a great range.
    Same thing as described above has happened : the little wire at the end of the metal tube has been cut.
    Now car range is only 5 meters ...
    TQi has been inspected and the black wire is not cut.
    Brand new batteries have been installed in Tx, Tx has been inspected : no wire desoldered or such.
    Could you please explain how you've proceed to regain signal back with the antenna ?
    Thanks a lot in advance.
    Nicolas
  35. #35
    Alma, Michigan
    12,311
    That little bit at the end of the wire is the antenna. Everything else leading up to it is just for routing. Doing the following should restore functionality of the receiver.
  36. #36
    7,263
    ↑↑↑↑ What he describing Is how I did mine
    Quote Originally Posted by electronico View Post
    Hello,
    Nicolas
  37. #37
    Nov 2014
    10
    *** Thanks very much ***
    Car is up again !
    Happy new year !
  38. #38
    Dec 2014
    450
    Don't mean to sound too technical or a know it all. Used to work for Telco and design cell sites for living.
    For 2.4 GHz, the antenna is coax cable (ie: RG213). For AM, the antenna is a piece of wire.
    The RF wavelength's multiples is what u want the antenna length to be for optimization (minimal reflection loss).
    Formula for wavelength is: speed of light divided by frequency.
    Happy new year.
  39. #39
    Dec 2014
    5
    So, I cut the end of my antenna wire off as well. The end of mine has a metal piece at the end. I can't strip the wire as described. Am I looking at it wrong?
  40. #40
    Alma, Michigan
    12,311
    The metal piece is removable... or just cut that off as well. Then follow the diagram above.
