    Aug 2012
    40
    TX and RX question ( 27mhz )
    my little brother is using the older 27mhz TQ radio in his maxx , brand new batteries in both the RX and TX , his problem is that when hes driving it he can only drive it about 10-15ft away from ware hes standing or it will lose signal and drive off , is there a way i can tell if its the RX or the TX ? any way i can fix the problem ? , both of the antenna are fully extended , thanks guys
    Alma, Michigan
    12,314
    Check for breaks in the wire...
    keep in mind that just because the wire jacket is in tact does not mean the wire is in tact.
    Alma, Michigan
    12,314
    Aug 2012
    40
    im guessing its the reciever , was wondering if it was posible to just open the receiver and re-solder a new peice of wire for the antenna ? what gauge and type of wire should i use ?
    Alma, Michigan
    12,314
    Yes, it is possible to resolder the antenna.
    Just find a similar gauge multi-strand wire that is the same length.... about 22-24"
    Aug 2012
    40
    awsome , thanks guys , i figured it was posible , just didnt know if any ol wire would work
    Aug 2012
    40
    soldered up a new antenna and still no range with this thing , maybe 10-15feet max , its not the TX because i switched with mine and it didnt do anything diffrent , why would a RX just lose range thow ?
