Results 1 to 2 of 2
    Traxxas peak plus 6 amp charger questions.
    I've had my peak plus charger for a couple months and have really only charged one battery which is a 5000 mah lipo that I use on my slash 4x4 and I always balance charge it. But I bought two new lipo batteries for my e maxx and it seems that the peak plus won't charge one of them with a rate over 0.2 amps even though I set the charge rate at 5.0 amps. I'm not sure if it's the battery or the charger. Also, once it is charging at around .2 amps, it stopped charging at exactly 120 minutes which I thought was odd.
    It stopped at 120 minutes because the factory setting is 120 minutes. If the charger works with the other batteries, then it's not your charger. You can adjust the timing on the charger, what are the cells reading on the battery in question?
    FLM EMBE P4de "Digger" Slash MT Backsl4sh Summit
