    Question Reverse Rotation Motor...
    Is there anything special about the 'reverse rotation' motor out of the brushed eRevo other than the wires are soldered on opposite tabs than the standard motor?
    I have an eMaxx transmission I am using for a custom build and have found a deal on a pair of eRevo motors - of course the one is reverse rotation. My question is if I can simply wire the reverse one backwards and use it alongside the other? Being a 'stock' motor I don't expect there to be a lot of built in timing or anything so it shouldn't be a problem but thought I should ask first..
    Thanks in advance.
    16,871
    http://traxxas.com/forums/showthread.php?8928910-3975R-Titan-Motor
    Running the reversed motor (with timing advanced) with the polarity swapped will result in a slower, less efficient, hotter motor.
    Alt-248 on the number pad =
    Thanks for the reply. Why do I always forget to use the search feature??
    Apr 2007
    Northwest, AR
    1,294
    I was in the same shoes at one time and had a paid of reverse motors in an e-maxx transmission. ksb51rl is right. The motors have built in advance timing and running them backwards will reduce power, runtime, speed, as well and run hot. The motors are the same as the "forward" ones but wired and timed backwards.
    However there is a solution. The transmission will run fine backwards. Just flip your diffs so that they reverse the direction your driveshaft spins.
    Reversed motors + Reversed diffs = normal driving.
    Pay It Forward.
    16,871
    Quote Originally Posted by OCD RC View Post
    I think the problem with that is that he has one of each, forward and reverse, since they originated in a brushed E-Revo.
