Page 1 of 17 12311 ... LastLast
Results 1 to 40 of 677
    7,264
    My REVO-E conversion
    its been few months past that i transform my REVO 3.3 into a full ERBE. i have bought the e-revo chassis, MMM ESC/2200kv, e-trans, etc... to have what ERBE would look like. then, i swapped the front and rear end out of my revo 3.3. it has been a life changing to own an amazing machine. now, i got the itch to start another e-revo build by using all of my spare parts, but this one i'll be using the aluminum chassis, i have locked the trans to 2nd gear already with the 3 screw method but, i still think that it needs a better way to secure the 3 screws. so, my idea is to machine and mill a aluminum and shape it just like the clutch but with a larger diameter so that i can drill 3 holes for the screw, that way its much secure. i'll be posting some pics as i get things done, but for now this is what i've done so far.
    i'm waiting in the mail for my ERBE diffs, drive axles, wing mount/wing, erbe bumpers, and toe links. still needs few more parts to order but this is good for now, i'm trying to build this as low as possible and so far i have spent $60.
    just to throw some idea, some of you guys might have done this. this pin seems to break easily, so what i did is i use a screw pin that hold the input shaft gear and so far its been holding up.
    kansas
    8,169
    YEA haven't seen a good 3.3 BL conversion in awhile. You know the die hard Nitro guys cringe every time they see one of their own converted....Teheheee
    7,264
    well, none of my parts came in the mail today, but i got something done that should help me LCG of my battery by bending that part of the chassis,
    and move my tranny few mm forward.
    7,264
    added some more pics of how my batts set before the bend, i dont know how thick a single 4s lipo is but i stack my 2s together just to give an idea, as you can see the top of the trans can only be seen alittle bit here,
    then after the bend, trans are more visible,
    South of St Louis
    6,101
    Can you post a pic from above so I can see how the batteries sit on the chassis? I've never seen one with a chassis like this - I'm relatively new to eRevo's.
    7,264
    i still need to find a batt tray but, i'll have to wait cause i'm not sure what a single 4s looks like unless stacking my 2s is about the same size.
    4,849
    stacking 2-2s lipos hard case is the same thing just stack the 2s lipos you have and should be the result give or take a few mm depending on the lipo you buy, seen a couple different 4s lipos and they are big and vary slighty in height and lenght. look into the integy i know that name but they do have battery trays that arent metal, alum. they are plastic unless their plastic is cheap too by chance. might be big enough for a 4s lipo. i seen a few on rcplanet while looking for velcro battery straps.
    DEU 8:18 ESV
    3,271
    Interesting build...I like it.
    Rock n Rolla !
    7,264
    thanks craig
    7,264
    little updates, mailman drop off few parts today, I recieved my axles and center axles, 17mm hexes, front bumper mount, and rear wing mount. still waiting for few more things.
    that cvd are my option whether i put up front center or rear center.
    7,264
    update. fabricate some aluminum tray to hold my batts in place, still have to cut a slot for the velcro straps.
    Idaho
    1,206
    looking good. Keep it up!
    Emaxx #3903, MERV
    RPM/PROLINE
    May 2009
    Edmonton, Alberta
    3,632
    Interesting option for lowering the battery, curious to see how well that holds up. on the front bolt are you running a bolt/nut all the way through?
    Whats going on with the pinion on the trans? I keep looking at that thinking to myself, "that aint right!"
    7,264
    Quote Originally Posted by minirevobasher View Post
    thanks, minirevobasher.
    7,264
    its one of those idea that pop out of your head, lol. still need to put one more brace though and run it underside of the chassis. i was thinking of doing just one long bolt/nut at first then, i see i have some plastic stand off, so i went and use it and screw them both end, if i do find a aluminum stand off then i'll replace the plastic, this way it will be more stable and i probably dont need to put a second brace underneath.
    oh, that pinion, just ignore it, lol. but, i have my way of doing tranny 2nd gear lockout. i am replacing the 2nd gear with a 38t mod1 spur gear instead cause they are the same 38t. i have to mill a aluminum adapter to hold the spur inplace along with the main drive gear, atleast this way i eliminate 2 of the bearings that is not needed, so less weight. and for the input gear i'll be replacing the plastic one with a 13t mod1 pinion also. if this mod become successful, then i can go even wider gear combo like 36t/15t for speed run.
    7,264
    heres what my ESC tray looks like. it also act as a rear brace mod,
    still have to drill holes.
    Middle of the Pacific Ocean
    171
    Looks good. I just got some parts made from a friend of a friend. I copied Oomp's second gear lockout part!
    7,264
    Quote Originally Posted by all_rice View Post
    hey, atleast i'm not the only one here doing it hehehehe. you got any pics of your conversion?
    171
    I'll try get some up tonight. pretty much a 3.3 converted using the tekno kit!
    171
    Here you go.
    And the second gear lockout part that A friend made.
    Illinois
    33
    I love my converted E-Revo 3.3
    7,264
    that look nice all rice. where did your friend find that size of solid aluminum for the 2nd gear lock out? i need atleast 1 1/2 x 1 1/2 inch block of solid aluminum.
    Here you go.
    7,264
    this is what mine looks like as of now, all it need are wheels, motor mount and the BL system. i think i'm going to go over my $300 budget, lol. i have spent $90 and the BL system i'm looking at is $165 plus the wheels/tires $70
    171
    they make parts for ships and stuff. I gave him a pick of Oomp's part and than gave him the clutch and other parts. He did his magic and called me. I'm trying get more made!
    4,849
    both of those conversions look good. have you tried metal shop places humayra? they may be able to sell you what you need. i know we have a steel factory here in the next town over just not sure if they would sell any of that but cant hurt to ask. they always have scrapes they dont use or want for free or cheap.
    DEU 8:18 ESV
    7,264
    i might have to look around for some metal shop arond here, lol. i actually have a machining shop on my route and most they do are solid metal. i'll ask them.
    7,264
    well thats nice of your friend. is he into this hobby too?
    4,849
    they should have something what you need around there, its not too big. I'll keep an eye out sometimes i see metal things like that around stores and thrift shops. does it have to be alum only or can it be metal.
    DEU 8:18 ESV
    171
    The guy used to be when rc was expensive. The hobby shops around here suck so he pretty much got out of the hobby. He was into the tmaxx.
    7,264
    before i went to electric i have 4 t-maxx and one of them with twin 3.3 engine then i have a revo 3.3 that i convert it to a full ERBE. then after i have finished the conversion i have bunch of extra parts that just setting in the box, this is why i started this build base with all of my spare parts.
    heres my twin 3.3 t-maxx
    7,264
    on which truck? the body fits perfectly still with couple more new holes for the body mount.
    Quote Originally Posted by rustlersvxl4life View Post
    how you going to fit the body with such a wide chassis?
    7,173
    Love your conversion man!!! Excellent excellent build. I've also noticed you take good care of your trucks too!
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    171
    That thing must've been fun to tune! LOL
    7,264
    thanks, i'm just in the proccess of making my own motor mount from a quarter inch thick aluminum, i hope i can get this right, if not i try something different, lol.
    7,264
    yeah, its a bit tricky tuning that beast, but when i get it tuned right, it can run all day.
    7,264
    update:
    i put the electronics in and tested it to see how everything are working and i come across to a very strange reaction, my RX/TX are all bind and calibrated to the ESC but, when i have the TX antenna just under the RX box the signal gets cut out (from green light to red light) what causes this to happen?
    67
    The RX to close to the TX thing is a frequency thing. If there is anyone here that is good at math/physics/programming, they may be able to tell you the correct reason for it happening.
    But from what i've been told it's just the RX being flooded with the wrong frequencies due to the distance,
    kinda like shortening a tuned length MHz areal.
    You should really have the controller about or more than 70cm/2ft away from the RX when you turn them on and during use.
    There is a few other things it could be, but seeing as it seems to happen only whilst having it so close, it could be that.
    Or maybe the lower deck of the truck blocking it?
    Hope that helps!
    7,264
    Quote Originally Posted by Deisel View Post
    Hope that helps!
    whatever it is, it only happen when its that close, lol. thanks
    7,264
    took some pics of it today, only missing are my motor mount, battery straps and set of wheels.
    7,264
    mailman was nice to come so early this morning and rop this package off.
