    Maryland
    336
    Velineon 380 with VXL 3s??
    My sons 4 day old VXL 3m quit working last night so I called Traxxas and they are going to replace it I have a spare VXL 3s and I wanted to know if I can use that to power the Velineon 380 or will it burn the motor up? Also will his 1/16 batteries be enough to power the VXL 3s?
    No Limit RC of Maryland
    Sep 2009
    3,374
    it will power the motor easily without problems. The only issue will be the wire bullets, The vxl 3m system uses thinner wires/bullet connectors than the vxl 3s system. so you would need a wire adapter to connect the motor and the speed controller.
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    Maryland
    336
    Quote Originally Posted by noir 522 View Post
    Just checked and the bullet connectors are the same size
