Results 1 to 2 of 2
    Norway, Europe
    EZ Peak Plus #2933 - Storage charging mode - Only 2 amp when charging?
    Why does the "Storage mode" has to be limited by 2.0amp when I use it to charge up from 3,5V to 3.8V?
    Yes, I know the charger cant give more than 2.0amp when discharge but it can give up to 6.0amp (80w) when charging.
    If I want to charge at max amp up to 3.8V I need to sit beside the charger an manualy stop charging at desired voltage.
    Does it has to be like that?
    Summit 1/10,dW
    Digger 1/16,2.4z,4wd,XL5,LED
    Plano, TX
    yeap, pain in the butt but it is what it is
