Page 8 of 8 FirstFirst ... 678
Results 281 to 308 of 308
  1. #281
    482
    Quote Originally Posted by Nitroelectric View Post
    Thanks a lot man! Yea I got mine up near 65 so 50+ is a definite. How's your build doing btw? Glad to hear about others doing this setup.
    Mamba monster rustler 2200kv
    Traxxas slash brushless
    it going ok i lowered it with fuel line add a gyro my question is how good are xo-1 tires do they have good grip
  2. #282
    Rotterdam, Netherlands
    8,302
    Quote Originally Posted by momort View Post
    You can read the answer here
    Small tip: You can edit your last post and add information to prevent adding an extra post every time. Just reads a bit more easy
  3. #283
    404
    where do you guys get the weights from. also how do the xo-1 tires do for speed runs i heard they didnt work well on rustlers do to lack of downforce in the rear
    I got mine off eBay. They are 1/2 oz tire weights. Search them up, they are pretty cheap. If you search "tire weights" in eBay, the 4th one is the one I got.
    I'm not sure about the xo-1 wheels, but if you worried about the quality and wear, I highly doubt they are bad. They are used on the xo-1 which goes 100 mph, so I'm assuming they'd be a great addition.
  4. #284
    404
    Major modification here guys!!! Actually no...just cleaned up some of the wires.
    And AbSoLoot1, I think I'm going to keep my bumper because I designed the setup and stuff and I like the way it looks, but I have one question for you. How low is your bumper to the ground? Like in cm? Thanks because I feel like mines too low, but not too sure. I'm debating on whether or not I should change it.
  5. #285
    697
    nice!!!!!!!!!!!!!!!!!!!!
    SLASHING UP WITH MY PEDE
  6. #286
    404
    Quote Originally Posted by slayer3.3 View Post
    Thanks bud!!!
  7. #287
    404
    I might be dying my chassis. But I also want to dye my wheels. Is it okay to submerge foam tires in boiling water with dye? I don't want to ruin the compound of the foam itself, so I'm just a little worried. I thought I was going to test it this weekend, but because of hurricane sandy I don't think getting into Brooklyn is going to happen. They even cancelled the marathon! Well anyway I'll do it next weekend. Ughhhh. Can't wait till I can drive....
  8. #288
    404
    Used braided line to cover most of the wiring. Thank you so much djmaincheese for this idea!! I love the way it came out.
  9. #289
    404
    Latest mod which is something that has bothered me for a very long time. The on/off switch! I used a mount from my drift car, drilled 2 holes in the chassis and simply mounted it on. Here's some pics:
  10. #290
    482
    that build is looking nicer by the minute i think im going a different route with my build im going back to 540 size motor but a 4 pole 2200kv on 3s mod 1 24/36 gearing that should be good for 60mph thats good enough for me for the space i have to run my monster motor is going back in my emaxx but keep us posted on your build
  11. #291
    404
    Thanks a lot man I appreciate it. I keep on trying to plan a time to go test it on 6s (you know not being able to drive and all) and was going to go last Sunday but the place is closed due to hurricane sandy. Ughh I hate you Sandy!!!!
  12. #292
    404
    It's official guys. Saturday is the day....Sorry work and school has reallyyyyy gotten in the way for the past like month. I am sick and tired of looking at it. So now it will hit the asphalt on 6-cells...on Saturday.
  13. #293
    When you installed the 32t spur gear do you install a revo slipper clutch to make it work or do you use the stock clutch from the vxl? I'm building a 2200kv rustler to
  14. #294
    482
    I used. The stock
  15. #295
    404
    No I used the stock one.
  16. #296
    SLC, Utah
    3,432
    Oh, i love the way u mounted that switch. Def should list the brand, and part number on that if you would.
  17. #297
    404
    It's off of my old redcat racing drift car; the Lightning EP Drift. The part # is R-03008. Here's a link to it - http://www.redcatracing.com/03008
    Glad you like it!
  18. #298
    Aug 2013
    5
    Cool prb one of the gears is broke or it needs grease
  19. #299
    Sep 2013
    SoCal
    520
    Looking for straight up speed? Try a 36/28. I ran a 36/34, the pinion was off an HPI Flux, on my full FLM Rusty Conversion, with a MMP 1415, 2400kv, juiced with a Maxamps 4S, 6500, 150C. Gunned it @ 97.8. Could've dropped in my Maxamps 5S, but the Rusty is somewhat challenging to control at speeds of 100+. Also, I'm running an FLM main diff with the FLM tranny case. I've weighted the crap out of the front, slighty forward of the front shock tower. The only time I had any clogging issues was when I ran a straight 36/36 setup. However, the Rusty ran like a possesed beast. But the motor heats up wicked fast. Good luck with your project mate.
    Cheers!!!
  20. #300
    Baltimore,Maryland
    374
    Quote Originally Posted by quantumreality View Post
    Cheers!!!
    I'm really interested in seeing a video of a full FLM rusty running 97mph with the 2400kv motor on 4s.
  21. #301
    Dec 2013
    39
    Quote Originally Posted by Baltim0re28 View Post
    Did this ever happen?
  22. #302
    Apr 2014
    18
    I have been eyeballing this one.. Asked for a quote on the price. It doesn't have the extended chassis though
    And I don't need the Velineon off course.. Can you even mount an XL2 or a monster in this one?
  23. #303
    Jul 2014
    28
    Any updates?
  24. #304
    RC Racer Octol's Avatar
    Feb 2015
    Oakland, ME
    188
    I love builds like this. Way to go bro.......
    Bashes well with others
    Rusty's & Revo's
  25. #305
    Feb 2016
    3
    Yeah I think it might have something to do with the esc because if it works fine not planted on the ground theres no reason it shouldn't do the same on the ground. thanks I'll try to get it working
    Once you get the straitened out loosen up ur slipper to help the power of the shaving ur trans. Just find that sweet spot
    Hope this helps
  26. #306
    Jan 2016
    Florida
    56
    You should probably change the tires
    If its not fast make it fast
  27. #307
    Sep 2016
    columbia,mo
    4
    love you rc by the way nice mounting of the esc
  28. #308
    Sep 2016
    columbia,mo
    4
    Quote Originally Posted by AbSoLooT1 View Post
    Well heres the thing about Giostealth. Its his application, Cuz hes setting up his application, to run his application, on the application, he can apply to get his application to run for 100mph application. . . APPLICATION!
    The guy is kind of a (enter letter here) "briefcase" I gave him some compliments, to which he replied in a "too confident" manner. so no thank you, or anything.... His reply to me saying, nice rides,was an LOL..... um ya..... Nice an all if he actually knew what he was doing, and most importantly, ever even ran a RC. His Grave Digger Stampedes tires say it all. If they had the same rubber tags new 1:1 car tires do, ud see it on all of his RCs. They dont get ran. I think that is so weak.. I like Puurrtyy RCs, But they spend as much time shiney, as they do covered in dirt. I clean em ALOT Air compressors help too. lol.
    *funniest thing however. Last night I was bashing, great session btw. One for the books. As I was doing so, a guy came, who we can title as a "one up guy" ... He says, I have a Tmaxx. which has "three gears" his words, and it goes 95mph. lol. SO according to him, u dont need any of this. Just a Tmaxx, and its "three gears" lol. to go 95, than go down a hill and ul hit 100. haha...
    he actually drives his rcs a lot he just spends way to much money on them to have show body and show tires...etc. I LOVE YOUR YOUTUBE CHANNEL BY THE WAY!!!!!... Application, lol. Where do you get your screw washers at.
