Page 1 of 3 123 LastLast
Results 1 to 40 of 103
    so cal
    9,244
    breaking a ring&pinion in?
    i recently installed new ring & pinions front and rear with aluminum bulkheads.i shimmed both where i had one too many shims and it wouldn't turn ,then took one out.when i spun the diff it was tight in a few spots just like everyone here has done it .went for a ride in the mountains jumps and bashing held up fine.went down in the flats to the street zipped around there but one hard stop flipped the car forward and stripped the front diff.
    took it apart sure enough front diff had 6 chipped teeth,checked rear diff had 1 broken tooth.pulled the rear diff apart took another shim !the ring & pinion had broken in and where before it wouldn't turn with the extra shim now spins fine!
    i think the ring & pinion might need to be installed and ran for a few packs then shimmed after it's broken in .
    i upgraded to aluminum bulkheads because in the last month i have replaced 4 ring and pinions that were all shimmed when new and didn't hold up.i will see how they hold up now.what do you guys think?
    Feb 2002
    8,528
    r e m o v e d
    TRUMP 16!
    Rotterdam, Netherlands
    8,298
    Are all bearings ok and is there any slop in the diff inside the bulkhead.
    Sent from my Transformer TF101 using Tapatalk
    so cal
    9,244
    No slop and everything is brand new. I am not asking if I have a problem to diagnosis. I am saying could this help someone who has bulletproofed there diffs and still strip ring gears.can breaking a ring&pinion in and then shimming it after help?
    Nov 2011
    324
    Well I just built my front and rear ultimate hybrid bulks from FLM last week. When shimming, I tried 9 shims total at first, but it was too tight and shafts wouldn't spin. So I took one out, nice and smooth. After running twice, I noticed the clicking sound I got when my stock diffs broke. I stopped and took it all apart again. The output and input shafts had alot of play in them. Nothing broke, luckily, but I had to add 2 more shims and it was nice and smooth, solid feeling. So I guess having to re-shim after a break-in period can be normal? Mine was just the rear, the front one is still solid feeling.
    FLM EMBE P4de "Digger" Slash MT Backsl4sh Summit
    so cal
    9,244
    Might be better to take it easy on a few packs then shim. We will see
    Atlanta, GA
    121
    I try to run 3-5 packs very easy, still wished the ring gears where a lil bit tougher, I have replaced mine 3 times and have had m MERV for less than 6 weeks.
    Also 50togo thanks for ur help.
    so cal
    9,244
    Yep we will see how it goes
    Alma, Michigan
    12,314
    I agree that a break in period then re-shimming would warrant a stronger mesh.
    It just makes sense... it is not like re-shimming is going to hurt anything in either case. lol
    edmonton, alberta
    289
    I heard that some people set them tight then take a drill to the shaft to wear them in..
    if its not broken, bash harder
    so cal
    9,244
    I tried that but loosened up a bit and still broke in more on the first ride.might need power and deceleration not free rev
    so cal
    9,244
    So far holding up good. I will keep on testing it
    568
    Let us know 50. I never thought of that, I just assumed all u had to do was shim one time
    so cal
    9,244
    That was the standard
    568
    So did it work out good the way u did it
    so cal
    9,244
    I am converting it for speedruns.lowering it with stock shocks with limiters ,3.2 rate springs, 100wt oil,and sway bars to be all ready for my neu 1110 1/y motor with brand new foams mounted on hpi 2196 web rims or keep it the way it is now so I can jump!
    568
    U buying a neu? Would u consider parting with your old one?
    so cal
    9,244
    i got cobra's
    so cal
    9,244
    like you need it! i want to test it ,see if i can run a single battery in the mountains -jumps and bashing.don't really want dual's up there.and parallel for speed runs .i will have 2 boost 2 cell and 2 boost 3 cell just in case.
    then after the speed runs with the on road setup back to the exotek shocks and dirt hawgs for all around fun. had to find a project my merv was maxxed with regular bolt ons.
    i think i will keep the 6000kv as a spare
    so cal
    9,244
    [QUOTEremoved=jimbo74;5193789]r e m o v e d[/QUOTE]removedewmovwd
    so cal
    9,244
    Latest update - 6 speed runs with new combo neu 1110 1/y and mmp dual 3 cell boost and 35/45 gearing.ran out of running room but 65 MPH and diffs are holding up great!
    8,298
    Good to hear. I am wondering what your findings of that combo are compared to the got2gorc set.
    so cal
    9,244
    Hard to tell power wise I didn't run the 6000kv lowered and on foams .both motors hit over 60 easy but after 5 speed runs the mmp was 120 degrees and the neu like 110 where the 6000kv would be a lot hotter .need to find a longer smooth road for a good speed reading .the 65 on GPS had full throttle for about 2 seconds before I had to shut off
    8,298
    Ok. Thanks for that info. Nice temps. Quite a price for the motor tho. I'm still looking at the Leopard 28mm motors, but those have that stupid 4mm shaft.
    so cal
    9,244
    Yep. I saw that when I checked them out!
    8,298
    Hmm. Just found a 5-4mm bore reducer.... 5mm 48T pinions enough.... doubts doubts....
    so cal
    9,244
    the 6000kv motor made good power but any gearing over 23/45 you would have to watch the temp .
    with the neu 1110 1/y i ran 25/45 with 4" summit tires bashed one battery after another and temps didn't go over 120
    so cal
    9,244
    Just did a motor test with the castle link. My 4550kv ran a 5058kv! Which makes sense the speed calculator with 27/45 on a 2 cell showed 43.6MPH and it ran 48.8
    Idaho
    1,206
    After i got done shimming my diffs, i was on the deck so i was barely tapping the throttle. Went to go eat dinner then i started to bash. I noticed when i gunned it up the curb it was a clicking sound.
    Do i need to add some more shims?
    Emaxx #3903, MERV
    RPM/PROLINE
    so cal
    9,244
    how much driving did you do after the shimming? and was the ring&pinion new or old? doesn't sound good
    California
    4,840
    i would have broke the diffs in after shimming for about a whole pack first to set the shims in first. I did this and worked out good even with a slighty damaged ring gear still (had stripped 3 teeths on it but didnt have a seal kit to replace since screws are stripped from factory). working great so far i can punch it on 2s lipo without any clicking anymore. if you drove it like 5mins first easy then went and hit full throttle then i think there is your issue. you needed to take it easy first 1 whole pack after you shimmed. open it up and take a look if there is no damage then add another shim or 2 and spin it like if you were reshimming ok if its ok then put back together and take it easy 1 whole pack if using 2s lipo ok if using nimh then about 2 packs since they dont last long thats what i used also 2 nimh's and 1 lipo for break in.
    DEU 8:18 ESV
    Idaho
    1,206
    I realized that i put the shims on the wrong side lol.....
    So far shim 4 and 3 are gone. Down to 2. But i took a break for awhile.. will get done tonight.
    I drove around on my back deck barely tapping the throttle before i did some on road bashing. Same pinion not new.
    Emaxx #3903, MERV
    RPM/PROLINE
  33. #33
    California
    4,840
    yeah put it on the right side of the diff wont work the other way, i bought 2 packs just in case and for the front too just in case still gotta do that one.
    I'll be putting a new ring/pinion in sometime after getting back home from vacation hopefully dont have to do it up there if i break down .
    DEU 8:18 ESV
  34. #34
    so cal
    9,244
    Quote Originally Posted by mike-susieq1 View Post
    i have my front shimmed good but also lowered the brake power with my mmp to 25% .nothing will take out a front diff like a too much braking strength
  35. #35
    California
    4,840
    got it shimmed the front now took a little longer than i wanted but i cleaned and put some 60k diff oil in the front diff, it was bone dry in there. now its turning smooth and used 1 shim only i tried 2 but was just a bit too tight so i took it out and left 1. i need to change rear and open it back up again to change the screws on there. got any ideas how to take a stripped screw off there without damaging anything? i have some screws that would work for it.
    DEU 8:18 ESV
  36. #36
    so cal
    9,244
    That would be difficult I have some craftsman easy-outs that have worked in the past but a seal kit 7080 at only 3.00 is alot cheaper if you could drill out the bolt heads which is also almost impossible without a drill press
  37. #37
    Idaho
    1,206
    Use the dremel and just cut out like a flathead size on the top
    Emaxx #3903, MERV
    RPM/PROLINE
  38. #38
    California
    4,840
    think i'll just have to pick up the seal kit and just take out the other 2 screws and somehow just spin or snap off the old seals without damaging the gears inside. i really want to get some diff oil in there 60k its real thick in the front one. i think it would help alot in the rear.
    DEU 8:18 ESV
  39. #39
    so cal
    9,244
    i run 50k in the rear and the rear will come around with too much throttle. i think 60 would be a bit much
  40. #40
    California
    4,840
    i dont mind the throttle i've been doing good with throttle control lately. 60k was the only thing i pick up as of late. i'm picking up some 50k shock oil as well in my next order on amain right now. i know i am missing something just not sure what. i got knuckles, seal kits x2, shock oil, bearings for steering, not sure what else i should get thats not too pricey for either my merv or emaxx. humm
    DEU 8:18 ESV
