Page 2 of 5 FirstFirst 1234 ... LastLast
Results 41 to 80 of 165
  1. #41
    San Jose, Costa Rica
    704
    hmm i would try to see if you could mesh the heat sink fins together to better help heat disipation from the esc to the colling unit above
    I used a little piece of metal in the center of the ESC with thermal paste.
    Quote Originally Posted by CarGuy7a View Post
    If you wanted to add even more cooling to the system you could get a 5v DC computer fan and mount it behind the radiator to pull air through it. If you wanted to conserve some space you could also look into retro fitting a computer CPU water cooling unit. They are a little more compact and already have a cooling fan setup mounted to it.
    I was thinking the same thing.
    That sux, silly me, I thought costa rica was a US territory. DOH!
    No, Costa Rica is an independent country.
    Maybe you be confused with Puerto Rico.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  2. #42
    Aurora, Colorado
    317
    +5 for creativeness - 5 for effectiveness, I don't quite understand the point of this, you are running 23/90 which is a bashing gearing, it should keep your temps below Fail safe 180*, second: heat sink on motor will reduce your temps by 15* which is about what you got, fan on ESC will reduce 5-10* temp on average, good fan for motor will reduce temps even more. The guys at my local hobby shop have done this many times to beat the heat, but for 31/76 gearing there is nothing that will help you to reduce it below 170*
  3. #43
    704
    Quote Originally Posted by Agriganosa View Post
    First at all: Thanks for the review
    Now, I am testing new gearings, I made a modification to the pump connecting the wires to the connector of the ESC. (Add more voltage and it can push more water), using tubes with more diameter and less curves, with the modification I made to the ESC the temperature goes down, i am adding fans to the esc and the radiator, and all the info I said before was before all the modifications made.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  4. #44
    704
    Lightbulb Update
    Today I made a piece of metal to cover the water cooling jacket.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  5. #45
    13,596
    This is so sweet! I seen that water jacket on a boat in an ad in RCCA today. Keep it coming...
    Ya can't polish fertilizer...
  6. #46
    704
    Ok thanks
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  7. #47
    704
    I was searching for aluminium gearbox and i found:
    http://www.ebay.com/itm/Lightweight-...#ht_500wt_1413
    http://www.ebay.com/itm/Traxxas-Slas...ht_1101wt_1163
    http://www.ebay.com/itm/390403402677...ht_2252wt_1163
    I want hear about some reviews about those gearboxes
    I have few questions about the gearboxes:
    I need a modification in the chassis to fit the gearbox?
    I am not going to buy a gearbox, is just for help a friend.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  8. #48
    13,596
    you will def get more cooling with the full alum gearboxes. I have the Hot racing graphite/alum setup, and while it does aid in cooling, it will not do as well as the flm or golden horizons you linked to.
  9. #49
    13,596
    I think only the rustler needs a slight chassis mod to fit the flm. The other 2 will fit all the 2wd traxxas trucks with no mods.
  10. #50
    704
    Ok thanks for the help
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  11. #51
    704
    Update
    Today I did this modification. Thanks M n M. It works , but just wins few millimetres
    That's it for today.
    Thanks for reading
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  12. #52
    I may try this to my future slash
  13. #53
    704
    I forget say if you want this modification for other cars or trucks (only traxxas trucks) let me know
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  14. #54
    North Central OH
    1,050
    DBG this project is darn impressive you have taken on and continued with, nice work man!
    Here is another avenue to consider perhaps on coolant, check out Red Line products and look for 'Water Wetter' it may interest you That water jacket is clean looking on the motor, coooooool!
  15. #55
    704
    Quote Originally Posted by kwitty View Post
    Thanks
    I am going to take a look the 'Water Wetter'
    Thanks for the suggestion
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  16. #56
    704
    Lightbulb Update
    I changed the tubes. Now, the new tubes have bigger diameter than the old ones.
    I forget made the unit conversion.(sorry )
    Ambient Temperature: 24-25C
    Gearing: 86-23(I changed the gearings to 90-23 to 86-23)
    Motor:30-37C (Never touched the 40C)
    ESC: 30-36C
    Next time i am going to buy a bigger pinion and a smaller spur gear.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  17. #57
    El Cajon Ca
    1,805
    As far as the coolent you are using.... In my full size turbo powered off road buggy I use a product called "Engine Ice" and it greatly reduced the coolent/engine temps. I don't know if that product is available where you are but it is also non corossive and biodegradable. Just a thought!!!!
    "enjoy your ride"
    Dennis
  18. #58
    704
    Ok, thanks for the suggestion . I am going to search if these product exist here.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  19. #59
    Feb 2010
    Mile 300 Alaska Highway, B.C Canada
    535
    That's TOO COOL!! pun intended.
    If I did this to my Slash I could go 200miles through the desert at 60mph with ultra cool motor. (With {Plutonium 239} batteries of course)
    XO-1, Roadrunner Slash
  20. #60
    704
    Quote Originally Posted by judgegixxer View Post
    Thanks
    I really want to see your setup. Did you have a pic of your setup?
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  21. #61
    Feb 2010
    535
    Quote Originally Posted by DBG View Post
    Thanks
    I think I'm going to add that waterjacket to my next order.
    [IMG][/IMG]
    [IMG][/IMG]
  22. #62
    Ontario
    989
    Simply awesome What are you using to power the waterpump?
  23. #63
    Lansing, Mi
    357
    For a castle motor I wouldn't get the aquacraft water jacket. I would look at some aluminum ones made for castle motors. I've purchased a few for my boat and they don't leak at all. I would put a link but don't know if i can push others products.
  24. #64
    13,596
    ^^^ I think its fine to post a link in this case as you need to reference a particular part to a particular person(reference purposes). Your not trying to turn the whole world on to the lowest price for it, but to show a member what else he could use for this application.
  25. #65
    Lansing, Mi
    357
    On that note. Here is a bunch of good waterjackets.
    http://www.offshoreelectrics.com/pro...+Water+Cooling
  26. #66
    704
    Thanks
    I was using the extra plug in the esc but now i am using a channel from the reciver.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  27. #67
    704
    Lightbulb Update
    Today I bought some fans and I installed to my radiator.
    I removed the radiator for a better view..
    Right now, I am connecting all the wires from the fans to the ESC fan plug.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  28. #68
    Knoxville, TN
    592
    that is awesome
  29. #69
    704
    that is awesome
    Thanks
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  30. #70
    704
    Update
    I forgot say an update yesterday:
    Yesterday i received a new gearbox, because my old gearbox have signs of fractures
    Now with the picsSorry for the bad quality of the pics, it was taken with my cell phone.)
    Is a hot racing gearbox.
    Now my motor is hypercooled
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  31. #71
    El Cajon Ca
    1,805
    I just bought the same tranny and changed it out yesterday. Have not completed replacing other things so have not had a chance to test it out.
    Good luck with yours....
    "enjoy your ride"
    Dennis
  32. #72
    704
    Thanks.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  33. #73
    704
    Revived for the new people.
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  34. #74
    669
    that's really cool. i wouldn't have thought of that myself.
    "That don't make NO sense!"
  35. #75
    704
    Quote Originally Posted by seanycool View Post
    Thanks
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  36. #76
    3
    That looks great. That is a great idea. Maybe add a fan to the radiator? Pull more air? Do you have any problem with dirt on the track?
  37. #77
    704
    Quote Originally Posted by Wupaul View Post
    Something like post #67?
    Nop, I dont have problems with the dirt
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  38. #78
    704
    Little update
    Ok, today I connected the radiator fans wires to a J connector and the same for the waterpump:
    Pics:
    Waterpump:
    Maybe I am going to get a Y connector for connect the radiators fans and the waterpump.
    Thanks for reading
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
  39. #79
    52
    I am planning on doing the same thing to my 1/16 scale e-revo when i upgrade to Mamba Max Pro. Instead of adding a radiator, i will be mounting this to the body posts:
    http://www.ebay.com/itm/LOT-of-3-CRA...#ht_2071wt_742
    And i will fill that with ice. I will put the intake area of the pump through the bottom, and the warm water will come through the top , becoming cooled by the ice. i feel it will be more stable and less finnickey than the radiator method.
    any thoughts???
    I have the stock reciver on the vxl 16 merv, and i dont know much about the electrics of this project. What do i buy to attach the pump to the reciver, will it supply enough volts on my 2s lipos (7.4 v.), and would it just be easier to attach the pump to a 9v battery? would it work???
  40. #80
    57
    Is the fans blowing air out or sucking it in? Cool beans!
