Results 1 to 16 of 16
    12
    how bad is this? what will I need t fix
    Looks like I broke my chassis What other than a chassis am I going to need to fix this.
    view of rear end from bottom.
    Planet Vegeta
    651
    you broke your skidplate, not the chassis
    May 2009
    Edmonton, Alberta
    3,632
    Quote Originally Posted by f687s View Post
    you broke your bulkhead, not the chassis
    fixed. unless it took the chassis with it.
    12
    ok, so broken read bulkhead, broken skid plate (screw corner snapped off) and a cracked chassis.
    May 2009
    Edmonton, Alberta
    3,632
    Chassis, rear bulkhead, rear skid plate, would like to think that everything else is "probably" OK.
    Double check your hinge pins in case they bent when the bulkhead cracked.
    You can usually get a chassis with all the attachments (battery doors, shock mounts) from eBay really cheap. Much cheaper than buying a bare chassis from the LHS. check them out.
    12
    it looks like a job to replace to chassis... is that the case?, is there a tougher chassis available? I know it's be the topic of conversation before, but in the real world... am I better off sticking with stock
    12
    Cameron, you're in Edmonton?
    Calgary here.
    Shelter Island, Alaska
    110
    You can get a KD(Kershaw Designs) full aluminum chassis... Not sure how well it'll hold up but it may work for you.
    May 2009
    Edmonton, Alberta
    3,632
    Quote Originally Posted by natethegreat View Post
    Its a lot of work but nothing too difficult. Id say the hardest part of changing everything over is getting the front half of the center drive shafts installed. Its tough to get them lined up (well for me and my fat hands it is lol)
    As far as how tough they are, the stock chassis is pretty darn tough. Takes a heck of a wallop to break them, that's the nice part about the chassis it will flex a bit before it ever breaks. I would even venture to say it wont break till something else does ie: your bulkhead, once it let go the chassis had no choice but to follow.
    And yep im up in Edmonton.
    12
    I'm seeing that now actually. If the bulkhead wouldn't have broken nor would have the chassis. Integy makes some aluminum bulkheads, I may check them out.
    Now how do I get the bulkhead off this thing? Do I have to take the rear end completely apart?
    12
    This would be my shopping list from integy, looks like it would be expensive! Nobody seems to have stock of this stuff.
    Billet Machined Front Bulkhead for 1/10 Traxxas E-Revo Revo 3.3 T3295BLUE
    Billet Machined Rear Bulkhead for 1/10 Traxxas E-Revo Revo 3.3 T3296BLUE
    Evolution3 Rear Skid Plate for Traxxas Revo 3.3, E-Revo, Summit & Slayer(both) T3195BLUE
    Evolution3 Mid-Front Skid Plate for Revo 3.3, E-Revo, Summit & Slayer(both) T3196BLUE
    Evolution-6 Billet Machined Alloy Center Skid Plate for Traxxas 1/10 E-Revo T4112BLUE
    12
    also.
    add center drive shaft to the list of the busted.
    May 2009
    Edmonton, Alberta
    3,632
    I wouldn't waste your time or money with the Integy stuff. My opinion anyways. Some guys have run it with success, but i don't use and will not use anything from them. Very VERY cheap grade aluminum is used. And because it looks all purdy and shiny they think they can charge a mint for it.
    Rear bulkhead can be removed by pulling 5 screws. the 3 that hold your wing mount on, and your 2 shock mount screws. your whole rear assembly will come off in 1 piece.
    Oh sorry and your center skid plate, you have to remove the back 2 screws at least.
    Sep 2008
    Turks and Caicos Islands, BWI
    623
    Don't go Integy! Too expensive for far below standard quality - go Integy only for the bling looks! Imagine taking a hit like that again with Integy parts lol and you are way up the creek! I learned that the hard way! There are one and two good parts you may be able to get away with - skid plates maybe. But if you are a serious basher... On to the next one.
    Ray00
    E–Revo │ E-Revo BE
    ITCHY THROTTLE FINGER!
    3,271
    Unlucky mate...RC Trucks keep you busy.
    Rock n Rolla !
    495
    who makes good aluminum bulkheads then?
