Results 1 to 13 of 13
    solomon, kansas
    421
    Cut out on power 6s help
    My spartan is the new edition it runs for a wile but the when I hit half throttle it cuts off I check the esc my low voltage isn't kicking in yet I have spc 3s lipos I'm mad because this is like my 3 time running this I just wana run with no problems
    Yes Castle Creations is in KANSAS
    7,262
    i cant comment on this cause i have not run on 6s yet, but i would give castle a call to get the problem sovle, sorry to hear.
    TENNESSEE
    364
    sounds like you have a programming issue with the esc settings
    MINE ARE FASTER THAN GPS!!!
    Columbus Ohio
    128
    What prop are you running? It WILL happen if you over-prop.
    solomon, kansas
    421
    It's stock prop the only thing iv done is switch low voltage on from stock will castles field card work with this esc any one know
    Alden, NY
    158
    Did you switch your esc over from the stock bats to lipos?
    solomon, kansas
    421
    Quote Originally Posted by breeze400 View Post
    If u meaning Turing low voltage cut off on yes I did
    North East ,England
    36
    I had the same trouble and it was rust yes rust in the motor i had got water into it and there was rust patches within the motor. My motor was replaced by Castle.
    solomon, kansas
    421
    No kidding so should I take it apart and see then what call castle
    North East ,England
    36
    I would certainly give it a good swill out with WD40 then some light oil and try it again.
    wales uk
    65
    hi my spartan is doing the same iv only ever run on 2s no problems but now i bought some 3s and it runs for 30secounds full trottle then cuts out and keeps doing this put batteries in my e revo and no problems so im sending my esc and motor into traxxas on monday hope i get some joy
    solomon, kansas
    421
    A I ran it today but before i took it out greased my flex shaft and turned it on and ran sun wd40 thru the motor help bunches I just dot think my low voltage light works cause when I charge my 5000 mah 3 s lipos the almost fully charged up around 4900 sum ware around there
    solomon, kansas
    421
    Oh and I think u have to send ur moor and esc to castle not traxxas I think traxxas will ask u to deal with castle in kc Kansas
