Results 1 to 28 of 28
Thread: Tire Help
    147
    Tire Help
    im looking at ordering the jconcepts rolex and road rage tire combo. is this a good choice. also i have a tbone full skid/bumper and want to make sure that those tires will clear the front bumper. thanks for all the help you guys have given me. my merv is nearing the built proof point heading for big block.
    so cal
    9,244
    You should get some wider tires road rage won't be able to handle a bb
    If its only on road get some speed hawgs and hpi ss monster rims but you will probably have to trim the bumper
    147
    Not going bb until next winter. My merv is only 4 months old. I havent even ran lipos yet. Tires are next on my list. Just want to make sure they will work.
    I do mostly on road with some light gravel and dirt here and there. I just want a simi durable tire. From the looks of it the road rage will last the longest.
    so cal
    9,244
    That setup will be fine for a stocker
    Rotterdam, Netherlands
    8,298
    If you get Road Rage tires, I would get the Road Rage II. Those are wider and work better than the older Road Rages. My first Road Rage tires did nothing else but slip.
    so cal
    9,244
    You would even be happy with dirt hawgs
    And yes they work good in the street too
    USA
    159
    Get the road rage IIs and some dirthawgs for bashing.
    Summit. MM 2200kv
    E-Revo VXL CVD's
    8,298
    I agree with the 2 posts about the Dirt Hawgs...
    so cal
    9,244
    Peter you are funny. Don't you agree on your road rage II also!
    8,298
    Lol. I had Dirt Hawgs, Road Rage and Road Rage II. Dirt Hawgs are pretty decent allrounders. Both the Road Rages are useless off road.
    So agreeing on both is no contradiction
    so cal
    9,244
    Yep I have road rage, speed hawgs,holeshot and my favorite dirt hawg
    147
    ok im down to 2. road rage 2.2 or dirt hawgs 2.2? i mostly run on asphalt and want a long lasing tire.
    so cal
    9,244
    I think speed hawgs look better. Same compound
    147
    what gearing for dirt hawgs. i want one for 50 and the stock 30 but with new tires
    514
    Best tires IMO: get some Dirt Hawgs and HPI2196 wheels. I've had many different tires and these are the best, other than foams.
    147
    cobra did you need to cut your tbaone for the dirthawg combo?
    514
    You will if you have ballooning problems, but I think that I had to cut mine down to fit Speed Hawgs. Speed Hawgs look great, but dirt hawgs are honestly much better. Use the 1" Gorilla Tape from Home Depot or similar store to strap the tires and take your time and exercise patience while gluing. It's very easy to ruin a gluing job by not properly seating the bead of the tire in the wheel.
    Hamburg/Germany
    443
    Spot on. For onroad and light dirt get the Dirt Hawg I buggy rear tires Proline part #107100
    They are not perfect on any surface but decent to good on most surfaces. This makes them the perfect allround tyre imho.
    The compund is very durable/long lasting. I run my first set for almost a year now and they only started to wear a bit recently when i begun to run 3S lipos.
    For gearing, I suggest to start with 50/23 (thats the inluded silver "speed" pinion, that makes your electronics run cooler) and work from there.
    If your temps on motor/esc are ok, you can try 50/28 (original gearing, the black pinion).
    I run them with a TBone front bumper, no need to trim with Dirt Hawgs, but anything bigger you will need to shave off a bit on the left and right on the bumper.
    147
    thanks. that makes me not second guess my self. im getting the hpi mesh wheels with dirt hawgs. im thinking that im just going to use the fishing line taping method. seems like the tape wont hold up.
    514
    The fishing line won't work well on dirt hawgs, since their tread doesn't have "straight lines" all the way around. The Gorilla tape will work very well, I assure you.
    so cal
    9,244
    the hpi 2140 are even wider offset fit the same as the mesh but 10.5" wide from outside tire to tire with the dirt hawgs
    147
    just ordered hpi mesh and dirt hawgs.
    Hamburg/Germany
    443
    I have a question: Has anyone ever tried closed foam inserts for the tires?
    Like the Proline 1/10 Closed Cell Buggy Rear Inserts/. Any benefit in these, i could not decipher their marketing speech on the description?
    514
    I have the closed cell foams! I got them because they're perfectly balanced, not terribly expensive, and don't absorb water. They can be reused as long as they remain intact. They can't be used with speed hawgs or road hawgs because their shape won't support those tires well enough. They're perfect for dirt hawgs and calibers and such.
    Hamburg/Germany
    443
    Thanks! Mhm, now you have thinking..
    If i can get them local i might try them, if i have to wait for an oversea shipment, i'll pass for the moment.
    Too keen to try out my new Calibers.
    8,298
    Quote Originally Posted by CMD-J View Post
    You can get them from a place closer to home...
    north van canada
    580
    dirt hawgs are sweet
    Powered by Castle
    so cal
    9,244
    they are my favorite too
