Results 1 to 22 of 22
Thread: unbelievable
    n. california
    67
    Angry unbelievable
    just got the mip cvds installed, only two hard runs an the next thing i know the shaft that connects to the wheel side is gone so i don't know if the cup exploded but i can tell you this: the pin is gone but the set screw is still there. i used red locktite, the only thing i can think of is i didn't have the the little indentation toward the set screw, guess we will never know
    summit
    tekin 2250
    rx8 esc
    slash 4x4 ultimate
    5
    are you running the tekin in the summit
    n. california
    67
    yes. its ripping everything apart but I'm determined to make it more reliable. probably should stay off the street!
    summit
    tekin 2250
    rx8 esc
    slash 4x4 ultimate
    500
    Turn power control down to about 60%. No more broken parts.
    n. california
    67
    no more fun either
    summit
    tekin 2250
    rx8 esc
    slash 4x4 ultimate
    11,288
    Power corrupts.
    If the set screw is still in, but the pin is gone, its more than likely you didnt get the small flat spot lined up correctly. The only other scenario would be that the pin broke. And that IS possible. But even still, the set screw would have kept at least a part of it in place. CVDs aren't always the strongest answer. They still rely on tiny parts like pins and set screws... which inevitably become the weak link.
    90
    If you're not sure if you had the flat spot facing up, chances are it wasn't. This would most definetly be your point of failure. When installing mine on my Slash 4x4 I made sure the flat spot was facing up but forgot one axle...I figured "Meh it'll be right with plenty of loctite". Guess which one came undone and lost forever
    n. california
    67
    well i have a replacement on its way, gonna make sure this time that pin is in correctly!
    summit
    tekin 2250
    rx8 esc
    slash 4x4 ultimate
    Dec 2009
    41
    Hi out there over the deep blue sea.
    It really is believable!
    As an owner of a 2200MMM Summit with a lot of fine parts, I can show you what happened to my brandnew MIP's in the first test yesterday:
    I was hoping, they would do their job as well as in my 2 AX10 crawlers, but so I'm very disappointed.
    They are assembled exactly as they shall be. And I did not really overstress them.
    What I'm doing now is to make them more solid, drilling out the holes of the pins 2/10th of a milimeter to use 2.5mm drillshafts as pins, cutting the 4mm thread in both sides of the middle part for using 2 setscews and work it all out properly.
    Hope they will last longer than 45 minutes...
    Virginia
    824
    Quote Originally Posted by jp86gt View Post
    no more fun either
    It's a whole lot more fun to drive an unbroken truck than it is wrenching on a broken one.
    Punch control does not reduce your power or speed. It just reduces the shock to the drivetrain of hard throttle acceleration.
    No amount of beefing up your truck will protect it from lack of throttle control. 1:1 race cars come apart in the hands of an unskilled driver, too.
    ERBE, Summit, Thunder Tiger MT4
    Pittsburgh
    778
    Power corrupts.
    Brushless power corrupts brushlessly?
    J/K I've had the sickness before.
    Trying to figure out a way to keep the GPS mounted when slowing down a 15 lb truck from 60 mph is no easy task.
    That's subjective.
    Toronto
    2,419
    I set punch control to 100%, can still do all kinds of crazy things, but I DO them knowing there is no shock to any components, it's great. Even if it's only a 1 second dampening, it saves everthing.
    3,196
    so has anyone used MIP axles in a summit for a long term successfully?
    I heard they do ok in the stampede/ slash but I think the torque and flexibility of the summit dose them in.
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    86
    sounds like someone should custom make a set of cvd's with some beefy pins.
    Dec 2009
    41
    Yes, more or less.
    Some batteries after doing the work I explained above I lost one half of the MIP in an area of 100 x 50 metres with rocks, sand, grass and road. The drill-pin was broken. I asked my two sons to search for it and, I couldn't believe it, they found it.
    Costed me 10.- Euros
    Now I use other drills and protect the shafts with heat shrink tubes, so the half can't slip out.
    Works good since 6 sets of batteries.
    the middle of nowhere
    419
    That looks like a great idea.
    noir, I really want to try a set but they seem to not do so well in the summit like you said. I wonder if its more installation/setup error? Or if a simple mod like the above mentioned heat shrink would help.
    I've also been trying to rack my brain on a mod that would strengthen the stock plastic shafts but haven't come up with anything.
    Dec 2009
    41
    Sorry, the pics don't show up anymore.
    Have to change the upload service.
    I've thought about strengthening the stock shafts for a long time, but I didn't find a solution too.
    A little workup on the MIP's is acceptable, I think.
    Ok, the (not really low) price should be for good working parts.... so I don't understand MIP .
    3,196
    Quote Originally Posted by German View Post
    MIP .
    That's good, I didn't get a chance to study them and I thought those little blue boxes was due to my slow internet connection.
    Dec 2009
    41
    First test with the new service:
    Because of the greater diameter of the pins I had to file out the slits in the heads a little bit.
    A pic with the shrink tube will follow.
    Dec 2009
    41
    Here they are "unlosable".
    3,196
    Hope you are not paying for that service cuz I am still collecting blue boxes on this side.
    Dec 2009
    41
    Sorry, but yesterday I saw the pics, today they are lost.
    next try:
