Results 1 to 12 of 12
    Oct 2005
    GR, MI
    675
    battery plugs spark when i plug them in
    is this common? Every thing works fine.....
    Jul 2007
    Rc Room
    1,482
    Yes it's normal.
    Stop busting my canards!
    Jun 2010
    Miami, Fl
    6,731
    All my plugs do the same thing, pretty normal.
    Oct 2005
    GR, MI
    675
    ok, whew. I bumped up to 5s lat night and the spark was larger LOL
    Apr 2010
    Northern Michigan
    840
    I believe it's from the capacitors charging up. More voltage bigger spark.
    High Point, NC
    13
    For those of you that know, does the switch on the ESC have anything to do with this?
    I think my switch is defective. It doesn't turn off the ESC. It is always on when the batteries are plugged in.
    kansas
    8,657
    switch has nothing to do with the spark..
    I leave my switch on all the time. In time you will need to bypass it anyways..
    BrianG.....
    http://www.scriptasylum.com/rc_speed/nospark.html
    Shelter Island, Alaska
    181
    That switch is not working right, i just leave mine on and just unplug the batteries. My switch is actually taped over to keep it from going off when i flip. The spark with 6s is really big and I was afraid it'd light the truck on fire!
    Mar 2005
    Des Moines
    2,559
    BrianG.....
    FYI: You aren't supposed to use a pre-charge resistor on any of the Mamba line of ESCs. It even says so on that page.
    http://scriptasylum.com/rc_speed/
    Roan Mountain, TN
    204
    The best thing to do is if you plan on using a 4s or bigger battery. Get a 2s and plug it in and power up the system and drive it for about two min then stop unplug and install the bigger lipo and it should do a kind of pre charge on the caps. And for future info you are charging the capacitor not the resistor. The resistor is use to slow the voltage to the ESC.
    Jul 2007
    Rc Room
    1,482
    Quote Originally Posted by Mist_Raider View Post
    HeHe, It might if your truck is made out of cotton balls and kindling.
    181
    Quote Originally Posted by BL-Bob View Post
    lol It's made of more like duct tape and super glue!
