Results 1 to 21 of 21
Thread: Clutches?
    212
    Clutches?
    When they start to go is it possible that is will squeel under power it does fine slightly playing around but when i put it under any real power it squeels not blood curdeling but its a low wine/squeel .......And i just put some 3.3 trenchers on my truck will this bigger tire put more of a strain on my clutch???
    NJ
    559
    it realy could be anything from your slipper to your clutch or your one way bearing inside the trans.
    Quote Originally Posted by e-revoPCB View Post
    Oct 2007
    Plano Texas
    2,241
    squeling is generally from a glazed (overheated) cb. or the one way bearing as said above. now if the clutches are wore to where u only get 35% contact.. could be another possibility
    new york near a few big lakes
    538
    It will put more strain on you drivetrain running those. I would lower your gearing some, if it's the stock clutch I never really had them last all that long. Not sure the usage you have on your jato, I blew through two in a gallon and a half I like speed !
    rusler vxl, rusler xl-5, jato 3.3, losi 5ive T
    212
    Quote Originally Posted by f0rb3s View Post
    what are the signs of a glazed clutch bell
    527
    Look at it. If it's a shiny blackish colour, it's glazed.
    You should get a Buku clutch. Best investment.
    212
    Quote Originally Posted by Mind_Reader7 View Post
    I would have to remove hat to fully see the clutch bell ..but the part that is visable does look shiny blackish ....this means i need a new clutch clutchbell ???
    16
    527
    No. Lightly sand the inside with some 400 grit sandpaper, then clean it with degreaser or dishwashing liquid/water or alcohol.
    212
    if my clutch was going out or was out would it keep it from ideling it will idle with the wheels off the ground but when i put it on the ground it dies
    Jul 2011
    S. Jersey
    765
    What clutch are u using? if it's a stock clutch can be a worn out clutch spring.
    212
    stocker........ is the only way to look at the clutch is to pull the motor ????
    527
    Shouldn't need to pull the motor.
    Loosen the 4 bolts that hold the engine in place, and slide the engine away from the transmissions. It should leave you enough room to take off the clutch bell.
    If not, remove the spur gear (easier than pulling the engine).
    212
    so just loosen then if i have to pull spur gotcha.....check the spring what will it look like if bad ...
    527
    If it's bad, it won't be tight around the clutch shoes, it will be loose, and coming off. It should be sitting in the groove of the clutch shoes nice and tight.
    212
    is this any good For the money or should i just buy a buku replaement???...........http://www.ebay.com/itm/Traxxas-Jato...item3f1646bb67
    16
    NJ
    559
    My opinion from testing pretty much all the clutches is go with the buku. If you have your slipper adjusted properly it does not put any more strain on your gear box then any other clutch set up.
    527
    Those ones aren't bad, but I killed mine pretty fast, and extremely hard to install.
    If you don't want to spend a lot of money, get the MIP clutch.
    But the Buku is the best, and will last for ages, and then you can just order new shoes.
    Maryland
    107
    , I had the exact same issue, it wants to remain engaged because the clutch shoes are broken, I'm buying a new clutch today.
    Oct 2005
    18,754
    If the clutch spring was stretched out or broken it would allow the clutch to engage at low speed... It will stall when you try to apply the brakes, the wheels will spin if lifted off the ground because the clutch is not being held back by the springs....
    AS far as the O.P. I would just remove the CB and have a peek. I've seen bad bearings, a broken spring and a slipper do that exact noise....
    Founder of H.U.A.
    I spent What??
