    95
    Question Alloy inner diff case help????
    HI, i brought a alloy inner diff case from integy but my question is dose anybody know if the diff gears from the stock fit inside the alloy 1, because it seems that the ibar support dont fit and neither do the small metal end bits that hold the gears .. the diff gears fit but not in the same way as the plastic unit?? help please
    Apr 2007
    Valrico, FL
    1,678
    Quote Originally Posted by mrgreenfingers View Post
    Those parts (ibeam and end supports) aren't used in any of the alloy diff cups that I've seen. Those braces were Traxxas's "solution" for making the diffs able to handle brushless power instead of just making new 1/8th scale diffs which is what they should have done.
    -ERBE
    -Slash 4x4
    95
    ahhh cool man i thought so.. ill be puttin these alloy 1s to good use, tks
    Dec 2009
    Pa
    775
    you will have to do some filing down of the "I" bar to get it to fit. every alloy diff case that i have had to have me do some filing of the I bar. even my summit ones.
    Revenge 1/8 buggy
    95
    Ok thanks . So you think I actually need to use the Ibar? Will I weaken the alloy diff case if I don't use the Ibar ? Dremal in hand awaiting instruction lol
    Athens, Greece
    620
    i had the same and both front and rear cracked. good luck tho
    Dec 2009
    Pa
    775
    yes i would try that first check fitment. do a little at a time
    Revenge 1/8 buggy
