Results 1 to 12 of 12
    95
    Question throttle trim not workin??
    hey guys i changed my velieon motor to a 2400mmp sct. but now the throttle trim on the controler dont work yet the steerin trim is still workin ok ? any ideas? i done all the programing steps that came with the new motor , dont get me wrong the car is runnin ok wheeling and all that jazz, but there is play in the trigger before motor kicks in so need the throttle trim to be workin?? help please
    Lilydale, Victoria, Australia
    2,843
    Centre the throttle trim
    Set your throttle / brake EPA's (travel) at 100%
    Calibrate ESC to your transmitter
    Apply trim if needed
    Cheers
    Slash Platinum
    95
    sorry can you go into detail about the set your throttle/brake epas travel at 100 part and the calibrate esc to your transmitter bit? cos im a lil slow, sorry man .. thanks for your help and time
    95
    I've calibrated the esc to the transmitter , and all the lights are correct and car runs .. Just no throttle trim workin??
    2,843
    Read the manual for your transmitter
    You should know what EPA (End point adjustment) also called travel does
    Cheers
    Slash Platinum
    95
    thanls.. not! iv programed the controler and i still never see epa , and nothin i do seems to fix this issue
    2,843
    What transmitter do you have ?
    Cheers
    Slash Platinum
    95
    its the stock 1 traxxas link 2.4gh, .. sorry if i never explained properly.. i brought a slash 4x4 ultimate that came with a stock velieon motor that i burnt out and when i had the veleion motor runnin the throttle trim worked fine,, so i purchessed a mamba max pro short course truck edition motor and esc combo from castle installed it in the car , everything seems ok but i know it aint right cos i cant get this poxy throttle trim to work again.. ive gone thro loads of crap.. tried to program to controler program the esc calibrate etc etc.. gettin frustrated.. thanks for ur help tho my friend
    95
    heres a pic
    95
    2,843
    Page 4 of the user manual shows how to set the EPA's
    http://traxxas.com/sites/default/fil...24GHz-INST.pdf
    Try reversing the throttle channel on your transmitter and running the calibration again, if the motor spins the wrong direction swap any two motor wires
    Cheers
    Slash Platinum
    95
    hey thanks guys.. i worked it out lookin at page 4.. easy when you know how.. nice 1 crusey
