Results 1 to 12 of 12
    Jun 2010
    Miami, Fl
    6,731
    is this possible vxl6s marine esc-18000kv motor
    I just say video of an erevo powered by a vxl-6s marine esc and 1800kv motor, it seems to run really good, but my question is this setup appropiate, I thought the marine esc needed to be watercooled, any thoughts?
    Saskatoon, Canada
    480
    If it needs to be water cooled you would need some kind of water tank or radiator. I asked the same question and received the same answer. Anyway I think a 1800kv motor wouldnt have enough torque for a 10lb plus truck.
    Jun 2009
    W Monroe, Louisiana
    2,000
    Ive never seen it so maybe ask the dude who posted it his temps, gearing, batteries, etc.
    muscoda, wi
    1,245
    Quote Originally Posted by woog421 View Post
    any 1800kv motor should torpedo any e-revo. shouldnt it. the bigger the kv, the less you got. i utubed it.
    Jun 2009
    W Monroe, Louisiana
    2,000
    And RPM of the motor can actually hurt you with too much heat if its too high. Optimal is about 35-40,000 RPM
    2200*22.2=49,000 RPM
    1800*22.2=40,000 RPM
    7,262
    i found someone with this type of set-up.
    Traxxas VXL-6s Marine ESC with VXL Fan (waterproof MMM rebadged)
    - Castle/Neu 1420 1800kv motor
    - Castle 10A BEC
    - RPM Front and Rear Hubs
    - RPM Front Arms
    - RPM Front and Rear Bumpers
    - Hitec 7954sh
    - Traxxas aluminum Hexes
    - Traxxas red aluminum rear push rods
    - Traxxas Chevron Tires on Split 5 rims
    - Traxxas 3000mah 7cell nimh x2 (never used)
    - Traxxas Link 2.4ghz system
    - Proline Slipstream body
    humay has left the building, peace.
    Jul 2007
    Rc Room
    1,482
    Hmm 13ga wire on the esc and plastic for a heatsink. That's a downgrade from the Mamba's 10ga wire, but it's waterproof. The motor (1420 1800kv) is a double length version of the castle 1410 3800kv with stainless steal hardware and bearings.
    Jun 2010
    Miami, Fl
    6,731
    here it is the video.
    7,262
    yep thats the owner of that e-revo picture shown^^^^
    500
    As long as the esc gets properly cooled, whats the problem?
    Chances are the case and heatsink are modded to allow more surface area.
    An enclosed water cooled esc would not last long in a land based truck otherwise.
    Sep 2009
    TJHSST, NO VA
    1,055
    ok so i watched that video but i wanted to see what the inside looked like so i literally googled it and this is what i found, sorry if this is against the rules, im not trying to promote anyone it just has pictures which now arent on this thread. http://www.rctech.net/forum/r-c-item...proof-rtr.html
    look pretty cool but the motor looks really thin and idk how well that would work in the long haul
    sppppaaaaaaaaaaaaaaaaaaaaaccccccccceeeeeeeeee!!!!!
    Sep 2009
    TJHSST, NO VA
    1,055
    and i cant edit my post but.. i messaged him n ebay becasue i found the revo there and here is what he said in response to temps and power compared to a mmm
    "On 4s the ESC is less than 100deg. I havent had anything read over 98. On 6s its around 145deg. This ESC is a MMM that's been watercooled and designed for boats, but you can connect it to castle link and adjust a few things, but not as a MMM. I did run a MMM in it and I will say that it is more powerful than the system I have in it, but honestly this has plenty of power as it is. Standing backflips on 4s isn't bad :P"
