    322
    Bearing carnage.
    Had a some clicking, clunking, then no front wheel drive. odd. Ripped it apart assuming it was going to be the front locker for the 3rd time. Nope, bearings on the pinion gear this time.. Destroyed the bearings like I have never seen before, and killed the ring and pinion gears...
    This pic is a bit out of focus but you can see the shoulders of the gear are chipped bad.
    First time for me on this one.. 20 bucks and shes back up and running though!
    Sep 2009
    Victoria B.C Canada
    5,437
    I went to ceramic pinion bearings
    For that reason no issues since
    Sent from my iPhone using My fingers
    Mountains cant stop me
    they have tried
    322
    Nice, like my skateboard. Didnt even think of that. Thanks man!
    Sep 2011
    Earth, Milky Way.
    928
    Ouch! Nice carnage though!
    This is a signature.
    Sep 2009
    Victoria B.C Canada
    5,437
    Quote Originally Posted by markman View Post
    Mine were from boca got inner and outer pinion and wheel bearings... Not real cheap $60 but seem to be worth the extra money they are sealed and made for dusty and dirty conditions. The complete set is over $500
    That's just crazy
    they have tried
    May 2010
    Nova Scotia ,Canada
    1,246
    I have gone with avid steel shielded bearings. A lot cheaper than the ceramics and I haven't had in issue with these.
    78
    Especially on the Summit, you need to pull the seal out of the bearings and pack them with waterproof grease, then put the seal back in. I am working on a video for my youtube channel about this. I had the same problem and discovered my differential was full of water. I also found water in the transmission, inside the wheel bearings, and inside the reciever box. Waterproof grease is your friend!
    Sep 2009
    Victoria B.C Canada
    5,437
    I did the grease the bearings clean and repack. But they just couldn't take the abuse I was giving them. I have a brushless setup I run off and on as well. The grease really helps with the water issues though
    they have tried
