Results 1 to 7 of 7
Thread: Converting
    349
    Converting
    I was thinking about converting my revo 2.5 to a slayer.But is it worth it,how much will it cost and what parts do I need?.Thanks.
    naptown
    589
    pretty much everything from your chassis to your wheels minus the axle carriers. and if you going to just a slayer or slayer pro. and think when i priced the stuff to convert mine to a revo from a slayer pro
    349
    I didnt think it would be that hard.
    naptown
    589
    yea its not hard at all, pretty easy task. youll have to mess with your gearing seeing its set up for the bigger tires.
    Long Beach, CA, U.S.A
    121
    Woot I found it! This was my little chart was thinking about doing this to my revo 2.5r. This is what it will cost according to the slayer manual but e-Bay will drop it alot. I've seen 3.3 chassis for 10-15$.
    And for the spur gear and clutch bell since the revo tires are bigger was going to try and gear them for the smaller tires. Instead of getting a new slayer transmission don't know if it will work tho.
    Then I searched craigslist and ebay to try to find a used slayer pro for 250$ and found mine for 350$ with all the upgrades I wanted + more for 350$.
    I'm not sure if this is everything or too much stuff but I'm pretty sure it's correct.
    Revo 2.5r Conversion Slayer 4x4 Pro 3.3
    3.3 Chassis - 60$ Steering Linkage - $3.50
    A-Arms(Upper & Lower, Left Front) - $7.50 A-Arms(Upper & Lower, Right Front) - $7.50
    A-Arms(Upper & Lower, Left Rear) - $7.50 A-Arms(Upper & Lower, Right Rear) - $7.50
    Front Drive Shaft - $4.25 Axles(Front & Rear, Left & Right) - $10.00 x2
    Suspension Rods Front - $9.00 x2 Suspension Rods Rear - $7.00 x2
    Spur Gear- $3.00 Clutch Bell - $12.00
    Rims & Tires - $28.00 x2
    =200+
    Revo 2.5r, Slayer Pro 4x4 Picco .26 max.
    121
    Aw man guess the forums don't like my tabs lol
    3.3 Chassis - 60$
    Spur Gear- $3.00
    =200+
    oh for the suspension rod's there called
    "5918 Push rod (steel) (assembled with rod ends) (2) (use with
    progressive-2 rockers) .................................................. ..................... $7.00"
    front and backs are the same and they come with 2 but you need 4
    and the other ones are called
    "5939 Turnbuckles, toe links, 72mm (2) (assembled with rod ends and
    hollow balls) .................................................. ..................................... $9.00"
    they are the same part # for front and back
    They both come in a pack of 2 but you need 4.
    349
    Thanks RockOutRC I knew it would be dear but I was going to go cheap where I could.Did you do the conversion yourself?.How did you find it?.Thanks.
