    phoenix
    1,118
    velineon amp rating
    whats the amp rating on the velineon motor?
    phoenix
    1,118
    i figured it out. 65 continous and 100 max. i also found out that mah and c rating affects temperatures as well as voltage. i heard before that high voltage increases heat but read that if you dont have a high enough mah or c rating that it could cause a little increase in motor heat as well.
    South of St Louis
    6,286
    This info is direct from the manufacturer. What are you trying to figure out?
    Type: Sensorless Brushless
    RPM/volt: 3500 (10-turn)
    Wire size: 12-gauge Maxx Cable
    Max RMP: 50,000
    Weight: 9.24 oz (262g)
    Current Ratings: 65A constant / 100A peak/burst
    Magnet type: Ultra High-Temp. Sintered Neodymium
    Connection type: Solder tab / TRX 3.5mm Bullet
    phoenix
    1,118
    the battery i need. i read that if i dont have enough mah and/or a high enough c rating that it could increase motor heat and cogging.
    Sep 2010
    area-51 RC
    763
    a 30c lipo will be enough . for mah on nimh 3000 should be the least , 5000 is ideal same goes with lipo , you should stick to the higher mah rating pack .
    phoenix
    1,118
    ya im thinkin about picking up a ******* 2s. gonna start a new thread about that though.
