    May 2010
    263
    RPM Revo A-arms/what driveshafts?
    Hey guys im looking to upgrade my summit. Will the RPM revo a-arms fit or will i loose alot of the stance?and also what driveshafts should i got with? anything else i should upgrade? thanks
    Slash rocks!!!
    Jul 2009
    Ontario, Canada
    11,288
    The stock driveshafts are among the strongest you can buy... certainly if price is a factor they really are the best choice. The front RPM arms will fit with no modifications and no geometrical changes at all. you CAN use the RPM rear arms for an ERBE but they will shorten the truck. The Summit uses the long wheelbase rear arms... The RPM arms are the standard wheel base (they do not make a long wheel base set of arms). so you need to choose, stronger RPM arms VS shorter wheel base. IMO there is nothing wrong with the stock arms for most situations a summit will find itself in as it is.
    Alma, Michigan
    12,316
    Small correction to Pav's otherwise perfect response...
    The RPM arms do need modification to fit due to the bulkhead differences... the locker.
    Jul 2009
    Ontario, Canada
    11,288
    Good thing theres more than one of us... hehe.
    Alma, Michigan
    12,316
    Thank you for not taking offense to my post.
