Results 1 to 11 of 11
    Sep 2011
    Niagara Falls, Ontario
    243
    Clicking feeling in rear diff
    i was running my slash today and all of a sudden there was a loud buzzing noise coming from the rear diff area so i took it apart and everything look fine. i took the diff out and there is a bit of a clicking feeling, is it suppose to be butter smooth? I recently rebuilt the diff to change a seal about 2 batteries before.
    Laredo TX/ Reno NV/ Palm Coast, FL
    271
    Take a good look at the center bearing in the rear where the center shaft connect too , I had this issue twice
    Detroit, MI
    416
    nothing is broke just clean it and put it back together, check bearings. whens mines click i clean it and its ok plus i have a mamba monster on 6s and no problems
    Sep 2011
    243
    k thanks, all bearing were good
    Sep 2011
    243
    put it back together after cleaning and this is what i got
    http://www.flickr.com/photos/68802080@N03/7033541419/
    Sep 2011
    243
    does this sound fine ^
    North Florida
    676
    that sounds like your pinion mesh
    what about the bearing the slipper assembly rides on?
    fix, run, break, repeat
    Sep 2011
    243
    all the bearings in the rear end i have checked and there fine and i dont think its the pinion mesh
    12,274
    Is your driveshaft bent?
    Sep 2011
    243
    drive shaft looks fine
    sunset beach
    327
    this happened to my front end it may relate. i had a bearing with a bad seal and it looked fine but it had lost a couple balls got out and found their way into a gear between the teeth didnt notice that the first time around either, found it on the second rebuild
