Results 1 to 15 of 15
    83
    My Slash 4x4 front lights
    Hi,
    Here is my first attempt to make a proper front lights on my slash 4x4 ultimate.
    Here is the video:
    http://www.youtube.com/watch?v=bd8Si...VvrVc0sOXnNko=
    And here is a photo:
    http://www.pics.lt/view.php?filename=27IMAG0184.jpg
    Any comments?
    Corpus Christi, TX
    466
    Wow, that's pretty dang cool. Can you list the parts you used to do this with and where you got them? Link are good!
    El Sobrante, Ca
    10,211
    Nice! How does it hold up when the truck rolls over? Looks nice.
    Member of the 10,000 posts club
    83
    The "case" is made from aluminium U profile so no problem at all
    83
    3 pcs of high power LED (Philips lumileds type rebel)(output is minimum 230 lumens each)
    1 pcs of current stabilizer (if I can call it that way). I own and run a company which manufacturers LED fixtures so I used a 32V (low voltage) LED drive which gives a stable 700mA current
    And a battery: Lipo 3S (because a voltage drop on one LED is aproxx 3 Volts) so I needed 3 cells for 3 LEDs
    And of course a lenses on LEDs. 2 of them with 60 degrees angle and one is 40 degrees.
    83
    Here a image from inside.
    The led drive is covered in silicon.
    And I forgot to mension a beeper for the Lipo battery
    http://www.pics.lt/view.php?filename=54IMAG0174_1_.jpg
    Oct 2011
    Santa Cruz, CA
    55
    Those are incredibly bright. Some rear LEDs help with your point of reference in the dark as well.
    My son would have those destroyed after one battery though.
    83
    No he won't
    The construction I've made is pretty rigid.
    It allready had suffered like 100 meters of roof slide 3 serious crashes etc.
    About the rear leds.
    I can do that but i need another extra cells of battery in order to feed extra leds
    Oct 2011
    Worcester, Massachusetts
    1,398
    Those are bright! How much did it cost to make?
    SL4SH Mamba Monster-Rustler Mamba Max 2400kv
    83
    Battery from HK aprox 8 USD
    LEDs - 6 USD each
    LED drive - 20 USD
    Lenses - 1 USD each
    beeper - less than 1 USD (dont remember - bought it from HK)
    Total 50 USD
    Extra material - a peace of aluminium U profile, a piece of aluminium strip, rivets, cable, conectors
    2 hours of work
    83
    Aluminium is used because high power leds needs cooling. The cooler they are the longer they last
    Oct 2011
    1,398
    thats not alot of money, maybe ill have to make one
    83
    the only thing is to find a low voltage LED drive
    Sillion Valley, CA
    462
    Very cool light system, Great work you have here.
    I wanted to do something similar with less power, but never have the time, so I intend just to ziptie my Petzl E99 XP 2 Headlamp on whenever I go camping
    83
    Thats of course the easiest way :-)
    I mean to ziptie something on something
