Results 1 to 16 of 16
Thread: wont link
    Ankle deep in Misery
    22
    wont link
    I've tried many times I get to the end(i believe) but it doesn't seem to link. Anyone have a idea of what I'm doing wrong? Also I tried reversing the trottle as its backwards on my jato and I hate it. Again I get to what I believe is the end but it doesn't take. At what point is the link button on the reciever used?
    12,314
    The LINK button on the Rx is only used to bind the Tx and Rx.
    Once bound, the button is not used again.
    Your manual should have a menu tree in the back on how to reverse the throttle servo.
    This process starts and ends with a 4 second menu press on the Tx... it has nothing to do with the Rx.
    Tx = Transmitter... Controller
    Rx = Receiver
    22
    Guess I wasn't holding button when I tried reversing the throttle. & wasn't sure when to press link on rx when I tried linking. I'll try some more. Thanks for input
    12,314
    I would start by resetting your controller.
    You may have done quite a few things without even realizing it.
    12,314
    Controller off
    Hold both menu and set on the controller
    While holding menu and set, turn the controller on
    Release menu and set
    --Red LED will blink on the controller
    Press menu two times
    --Red LED will blink 3 times
    Press set on the controller
    --LED will turn into a solid green light
    ~~You have just reset the controller!!
    12,314
    Now, to rebind the Tx and Rx...
    Controller is off
    Press and hold the controllers set button
    As you are holding the set button, turn on the controller on
    Release the set button
    --LED will blink red
    RC is off
    Press and hold the receiver's link button
    As you are holding the link button down, turn the RC on
    Release the link button
    The LED on both the controller and receiver should turn green
    Once they do, they are bound.
    Once they are bound, the link button on the receiver is not used anymore.
    12,314
    Once you are to this point, let me know if anything needs to be reversed... or changed.
    22
    Thank you! I'll try here shorty.
    22
    SWEET! I bound it to a differant tx & throttle was still reversed,I then cleared settings & throttles now how it should be. Thanks you da man!
    12,314
    Your welcome.
    I kinda figured the Tx needed reset to factory...
    factory settings should be pull for throttle, push for brake.
    Steering sometimes needs reversed, but hardly ever throttle.
    22
    I bought it used & previous owner had it reversed for some odd reason. I've been switching all my trucks to the new reciever so I can run everything from one tx. I have the newest tx coming so hopefully it'll bind the same way?
    12,314
    Tx or Rx...
    Rx goes in your vehicle... if you want the same controller to operate multiple vehicles, you need multiple Rx's.
    They will all bind the same way.
    22
    I have the new TQi tx coming. I've read it'll work with the 2218 & 2218x recievers that I've been upgrading my older junk with.
    12,314
    They'll link up just fine.
    22
    Yeah thanks to you now i know how. Lol
    22
    Sweet got the new TQI controller today. No docking station but I dont need that right now anyhow.
