    45
    Unhappy how to remove rear axle?
    Hi guys I broke my first part today and it happens to be the rear axle and I have no idea how to get that part off can you guys help me out here I have th 4x4 slash thanks.
    216
    1) remove tire
    2) remove plastic hex and pin inside the hex
    3) remove grub screw near the rear diff
    4) remove screw from rear link above the diff
    At this point the axle should slide right out, and a replacement can be installed. Assemble the truck in reverse order.
    New Hampshire
    448
    Quick and Painless Well it should be haha
    RX8 Powered E-revo
    E-Slayer
    45
    The plastic hex nut looking thing towards bearing hub I don't see a pin I don't understand how to get it off.
    houston
    997
    put a flathead screw driver between the hex and axle carrier and pry it off the pin is behind it
    slash 4x4 and a blast on steroids
    45
    Thanks guys for getting back to me so quick so now comes the big question should I just replace with stock or performance and if performance what's out there for axles.
