Results 1 to 9 of 9
    Atlanta
    996
    Wink CyconXc's -- D8 Shock Setup
    This is a thread I wanted to start to help answer any questions about upgrading to Hot Bodies D8 shocks.
    I was tired of bottoming out hard on big jumps, so I decided to do something about it. It was either between these shocks, or the Team Associated SC10 4x4 shocks. Both I heard were very good, seemed very high quality, and cost around the same price.
    Hot Bodies D8's
    -8th Scale size & strength
    -More shock body volume
    -Bleed hole
    -Metal Shock Caps
    -Comes built in 97mm & 112mm sets
    SC10 4x4 Shocks
    -Less oil per shock
    -Bleed Screw
    -Plastic Shock Caps
    -Comes as a kit with 30 or 26mm shock bodies
    I decided to go with the D8's. I ordered 2 sets of 97mm for $40 each. Both in one pack come built, with a baggy full of mounting screws and 2 stand-offs. Got them from RCHobbies4Life.
    Setup
    3 Front Options:
    1. Just 97mm shocks on the stock front shock tower without changes. It will fit, but you have to mount them with the outer A-arm wholes. Not much ajustability.
    2. 97mm up front using shortened rod ends and Kyosho spring cup. Takes minor modding and added time to wait for the other order. Will make the D8s a little longer than stock fronts.
    3. Rear Shock Tower mod. Lets you run the shocks without changes and gives you back the ajustability.
    http://traxxas.com/forums/showthread...r-Up-Front-Mod
    http://www.youtube.com/watch?v=BafNfrTvK-I
    Rear Options
    1. Stock D8 setup works fine on the rear.
    2. Stock setup with longer D8t shock ends. If you want a higher ride height.
    Pics:
    With rear shock tower mod, front shocks use the stand-offs on the top, flush on the bottom.
    D8 97mm next to Traxxas Rear Big Bores. Notice they are the same length.
    Atlanta
    996
    Right now I'm running Losi 35wt all around, might need a little thicker.
    Mounting Pics: Let me know if more are needed.
    Fronts
    Rears
    Atlanta
    996
    Sillion Valley, CA
    465
    Very useful info. Thanks
    Jan 2014
    775
    Why did you pick the 97mm instead of the 112mm? I think the 112mm is closer to the length of the stock rear shocks.
    Atlanta
    996
    Quote Originally Posted by Emaxx Racer View Post
    You can see it in the above pic that the 97's are the same length as the Traxxas rears. I asked about the 112's but someone told me that they were too long. Once you add the D8T shock ends in the rear it sits much nicer.
    #customrctrophytruck
    RC Turnbuckle Jr. mwe-maxxowner's Avatar
    Feb 2004
    pageland, sc(south of monroe)
    5,387
    But, if it keeps your from bottoming out on jumps, how does it handle? Is the shock too stiff to move up and down with terrain, and allow the body to roll a little for traction in dirt and offroad?
    460, straightpipes, buried throttle, nuff said :D
    Jan 2014
    775
    Thanx
    BL Race Emaxx
    Castle/Tekin Slash 4x4
    Flux Scream Muggy
    Summit
    Jul 2016
    46
    When your d8's arrived pre-built, did they have oil in them, if so what weight?
    Secondly how. Do you get the tops off without ruining ans scratching them up. Thanks
