Results 1 to 20 of 20
    Southeast Michigan
    92
    Castle MMP SCT 2400 performance on 2S
    Hey all,
    I have read several times that the MMP SCT is a great motor/esc combo for the slash 4x4, especially for bashing. I have also read that it doesn't "wake up" until you go 3S or higher for your batteries. Since I have a lot of 2S batteries and a couple of 3S, my question is how does the MMP SCT 2400 compare on 2S vs. the stock motor/esc? Will I be taking a step back on those packs? Is it comparable to the stock on 2S? Even if it's the same or slightly better I will feel better about the purchase I will be making today.
    Any feedback from those who know is appreciated. Thanks!!!
    My money pits:
    Slash 4x4 Ultimate
    Losi XXX-T MF2
    Lilydale, Victoria, Australia
    2,843
    3800 is a better option if planning to run a lot of 2s
    See this thread
    http://traxxas.com/forums/showthread...tle-2400-Combo
    Cheers
    Slash Platinum
    Southeast Michigan
    92
    I will no longer be buying 2s lipos, only 3s ( have 2 now) and in the distant future, 4s. I just don't want to slap in the $250 upgrade, slap in a 2s lipo then say WTH... As long as the results are similar to the stock setup I will be satisfied.
    My money pits:
    Slash 4x4 Ultimate
    Losi XXX-T MF2
    2,843
    Wont be as fast as the stock motor unless you gear very aggressively (50% larger pinion), motor will draw heaps of amps
    Will have more torque and run cooler
    Cheers
    Slash Platinum
    Southeast Michigan
    92
    Trying to find the 3800 motor and can't. Should I be looking at the Castle site for this option?
    My money pits:
    Slash 4x4 Ultimate
    Losi XXX-T MF2
    2,843
    They are available everywhere (Tower, Amain, Ebay, Gonitrohobbies)
    Will come with 2 ESC options, the Sidewinder and the MMP
    Get the MMP
    Cheers
    Slash Platinum
    Apr 2001
    Queens, NY/Orlando, FL
    497
    Quote Originally Posted by JDGecko View Post
    If that's the case, go with the 2400
    Oct 2011
    Worcester, Massachusetts
    1,399
    98snakeeater knows exactly what to do, watch some of his videos and you will soon make up ur mind.
    SL4SH Mamba Monster-Rustler Mamba Max 2400kv
    Southeast Michigan
    92
    Since I will only progress to 3s in the future I am going with the 2400. Thanks for ALL of the input fellas...
    Are there any modifications I need to be aware of? Mounting plate for esc? relocation of receiver box, is that necessary?
    My money pits:
    Slash 4x4 Ultimate
    Losi XXX-T MF2
    Houston, TX
    627
    i redid my whole setup. i took the receiver out of the box, screwed the old motor plate to the chassis to mount the receiver, glued 2 pieces of lexan together with some lexan picture glue and screwed it to the front of the chassis and mounted my ESC in the front w/ double sided and liquid tape (works wonders). i need a new chassis and when i get one im gonna redo it again and run all the wires through the plastic braces in the chassis
    and if you didnt already have them. i would get mip cvd's and kingheadz motor mount
    56
    Looks like Koda's system is sensored.
    I tested a non-sensored Castle System this weekend and I was dissappointed in the stalling & unsteadyness that I believe is called "clogging?".
    I'm about to test a sensored system.
    4x4 Ultimate (Slayden Suspension<Big Improvement!)
    Apr 2001
    497
    Quote Originally Posted by KewlToye View Post
    It's non-sensored (the extra wires are for the cooling fan), but you're right about the cogging with the Castle motors (not smooth at all)
    I've grown used to it though.
    56
    I just bought a different namebrand truck with a sensored Novak system... It'll take me a few days to put it together. I'm curous how different the sensored system will act.
    I have a spare motor out of the deal that I may use to get my 4x4 going again.
    Houston, TX
    627
    Quote Originally Posted by 98 SNAKE EATER View Post
    hes right its not sensored and i too have grown used to the small amount of cogging but i do want to try a sensored motor out and see the difference first hand
    Michigan
    24
    I have the same setup and I run my old 2 cells on the indoor tracks, I found that I actually prefer to use the 2 cells inside. 18/54 gearing and use the field card to give the motor as much torque as possible. Then, when I'm outside I put in the 3 cell and let the fun begin!
    Also, I squeezed the motor and esc into the exact same places. Mount the esc to a piece of aluminum and use the 2 tapped holes in the chassis to attach the plate
    Columbia, SC
    317
    The sensored setup will have way smoother throttle response, take off, and is also quieter. I have a Tekin Rx8 sensored setup in my Rc8.2e buggy and I can make it creep along with no cogging at all.
    Traxxas gone bye bye!
    Dec 2006
    camillus, ny
    2,846
    Quote Originally Posted by Koda Dank View Post
    Why move every thing around? the fit in the stock location is perfect, just remove the stock esc plate and screw down a scrap piece of lexan and servo tape the esc in place.
    Man i need more than 50 characters.
    Can you use 2 2s with the parallel adapter
    2,843
    No reason why not if you want double the runtime
    Cheers
    Slash Platinum
    Houston, TX
    627
    Quote Originally Posted by Apexracing View Post
    better air flow to everything. with my esc up front it barely gets warm and with the motor having so much room it has somewhat of the same effect. i took the receiver out of the box cause i got tired of taking the box apart every time i wanted to change something on the esc.
