    Elyria, Ohio
    192
    MT slash gearing question
    My slash 4x4 has 2.8 talons at the moment. Ordering proline tires and rpm wheels. And the truck is lifted as high as it will go. VXL.
    I changed the pinion gear to a 9t. Now...the truck seems very slow. Not much stops it...but is slow. Would changing the spur gear help? The spur is what came stock in the truck. I want it to be a beast in the mud... but also have alittle more speed. Let me know.
    Thanks,
    Scott
    Jul 2011
    cali
    444
    yes to question 1. stock pinion is 13t the option pinion that comes with the truck is 18t. atleast go up to stock 13t if temps are to high try a 12 or 11t those will be faster than the 9t you can gear the stock motor from 9t to the 18t/54. jsut make sure you check your temps as you go
    Dec 2006
    camillus, ny
    2,850
    Upgrade to the mamba max pro and the sct 2400 motor and be done with it. Run 3s on a 18t pinion all day if you like.
    Man i need more than 50 characters.
