    69
    Best shocks for e revo
    Im new to the e revo brushless and am wondering if there are better shocks than what comes stock. Maybe all aluminum. Thanks
    Jun 2009
    W Monroe, Louisiana
    2,000
    Stock shock bodies are best since they are teflon coated aluminum. The plastic pieces (black pieces) can be upgraded to aluminum. However the actual design of the shocks are perfect. Are u using stock springs and oil? If u havent U should find your silver and blue spring colors in the box. Put those on and you will see a much tighter truck. Thick oil, stiffer shocks, and the $4 VDP kit helps with jumping and resisting body roll.
    I like mine super tight for bashing and jumping so i use some of the stiffest springs (blue/purple), stiffer/more progressive rockers (p3), 60/70 heavier weight oil (60/70), and a Variable Dampening Piston kit AKA vdp (#3 smallest holes).
    Nov 2011
    Springfield, Mo
    6
    Are you using the stiffer springs on 90mm rockers?
    69
    I'm using the progressive 90 rockers with Blue up front and silver in the back
    Jun 2009
    W Monroe, Louisiana
    2,000
    Well it should actually be silver upfront and blue in back. It will make a difference.
    kansas
    8,436
    Silver F
    Blue R
    80 wt
    P2 Rockers
    A bit of good preload
