Results 1 to 11 of 11
    197
    MIP vibration problem.....
    Got new MIP x-duty rear axles for both mine and my sons Pede 4x4. Mine are fine, but I noticed a wicked vibration on his. Thought they were the rear bearing carriers at first and filed the plastic carriers a little. Still had a bad vibration.
    Worked the suspension and observed it only vibrates when left rear arm is fully extended, vibration goes away when arm is compressed. Switched out parts with mine and was able to work it down to the upper female link attached to the rear differential.
    I red loctited the pieces so I haven't been able to switch out the upper female shaft with another. It seems to bind when it is at the max angle with the arm fully extended.
    All the other joints and shafts have no problem.
    Thoughts......experience?
    El Sobrante, Ca
    9,093
    You may have gotten some loctite on a part that restricts movement. I did that my first time putting them together. I recommend blue loctite. Take them apart, clean then really well and reinstall. I think it will go away.
    Slash Ultimate, ET-3S 2400 MIP King Headz RPM 3PL
    197
    Any ideas on removing red Loctite?
    Oct 2011
    WI
    83
    The best way I've found to remove red loctite is to use heat. If I can't apply heat directly to the fastener that is stuck, I'll heat up the wrench first and let the heat transfer into the fastener. I don't use my good tools to do this though. Ill use a cheap "L" wrench so if it gets damaged its cheap to fix.
    El Sobrante, Ca
    9,093
    If you have a soldering gun, put that right on the screws. That will heat them up!
    197
    Got the screw out with a butane lighter.
    Called up MIP and a new drive output and rebuild kit is on way thanks to warranty. A solid out to Matt at MIP for great customer service.
    Oct 2011
    WI
    83
    That's a good idea! I'm defiantly going to use that one.
    Oct 2011
    WI
    83
    Quote Originally Posted by Summitvxl View Post
    That's good to hear they stand behind their products.
    El Sobrante, Ca
    9,093
    Called up M
    How long is the warranty?
    20
    Did you ever have trouble getting something apart after putting it together with blue loctite?
    El Sobrante, Ca
    9,093
    Quote Originally Posted by bruggar1 View Post
    It is a little tight. It all comes loose with little work. Holds together great
