Thread: pinion gears
    East Quogue, New York
    155
    pinion gears
    What is some good makers of pinion gears. Need a 5mm 32p 16 tooth pinions. We have tried Novac and they didnt last long. One lasted about 5 packs and mine lasted till I burnt up a bearing. I think we might try some traxxas brands but was just wondering if you guys have had better luck with others.
    12,600
    I have tried many different brands. They all work the same for me. Maybe you have them set too tight?
    Apr 2001
    Queens, NY/Orlando, FL
    499
    Only problem I ever had with a pinion was the stock 13T (split at the grub screw)
    I have just about all the pinions Traxxas has to offer, but I'm currently running one from Robinson racing without issue
    Also have one from Castle on order
    North Florida
    676
    I've never seen a "bad" gear of any type from Robinson Racing, whether it be a pinion gear or internal transmission gears, but that's not saying other brands are not as good either
    fix, run, break, repeat
