    103
    Recommendation on a good motor fan heatsink
    I'm running only 2s, stock gearing, slipper, esc fan, temps in twenties, and I run it hard threw the grass and motor is super hot after maybe 10-15 min(I don't have a temp gauge but very hot to touch). I even smelled some kind of smoke afterwards but seems motor and esc is ok, I tried after it cooled off.
    I'm thinking I need a really good motor fan heatsink any suggestions.
    12,697
    Integy make a good single fan setup. The dual fan will overload your bec.
    103
    Yea, I know about the one fan, any links on a good fan.
    I use it with outerwears but a bit of water and slight dirt still gets in, so needs to be durable thanks.
    58
    I've been using the integy one that El Sob mentioned for about a month now. I also run with an outerwears and I've had no problem although I don't run through anything wet. They're only about ten bucks so you're not out a ton if it takes a crap. Honestly, I think the heatsink it's attached to does much more to dissipate heat than the fan will ever do anyway. I run 2s lipos and I've yet to get it over 130ish.
    Edit: http://www3.towerhobbies.com/cgi-bin...&I=LXWMC9&P=ML
    103
    Yea I do like that but I think Integy or another company makes a more robust type metal grill instead of just the clear plastic fins
    Wesley Chapel FL
    101
    I use a ******* heat sink/fan combo and although the fan didnt last very long it cooled great and it is huge. I have ordered another fan and it should be here next week. I had to do a little dremeling to get it to fit but I enjoy that and its worth it in the end.
    http://www.ebay.com/itm/390263218708...84.m1423.l2649
    and my new fan came from here
    http://www.buyextras.com/ev50dc5vbabe.html
    North Florida
    676
    does the fan on that Integy one just plug into the fan plug on the VXL-3S?
    anyone know exactly what mm size the fan is on the Integy heat sink? if I order one I'd like to order a grill to put over it too. looks like maybe 30-40mm?
    fix, run, break, repeat
    Wesley Chapel FL
    101
    I believe the integy is 30mm
