Results 1 to 19 of 19
Thread: Slashenstein!!!
    New Jersey
    259
    Cool Slashenstein!!!
    Whats up all. Long time viewer fist time poster. haha.
    Anyways, I have a 1/16 Slash, some upgrades. And i was thinking about possibly installing rear a arms from a erevo, or summit.
    Has this been done before? Im assuming no becuase i cant find anywhere that someone has. First thoughts is that it would work, considering its the same chassis. I can see me also having to replace the the rods and maybe the axles.
    I know my rear tires will stick way out, but thats kinda the idea. Also the added stability will make 50 less expensive, lol, seeing as parts break easier at those speeds.
    What are your thoughts everyone?
    Thanks Yall
    Feb 2002
    8,530
    it will be a 4wd buggy..... i dont know, i think i would stick to just converting it to a merv......
    TRUMP 16!
    New Jersey
    259
    Yea thats always an option. But i wouldnt mind being different. The summits a arms i understand are at a different angle as well, right? So that would technically rake the front end without having to adjust my suspenstion, in theory.
    Feb 2002
    8,530
    the summit has the same front arms as the merv
    it's rear arms provide a longer wheelbase, but those thigns shred axles... and the summit axles are more expensive than the merv axles, which are better than the summit rear axles... and using the summit arms on the rear, you wont be able to run a hard shaft liek a cvd....
    i think they are a retarded idea....
    as fo the buggy thing, it might look different, but i really don't think you are going to see any improvement from it..... i would go to a full merv swap, that is, front and rear merv arms and axles.....
    TRUMP 16!
    12,314
    I have thought about this myself... I even have all the parts, owning two 1/16ths.
    1) You would be better off not using the Summit rear arms.
    2) You would need to swap the rods and axles along with the arms.
    Since most of these parts (at least in stock form on eBay) come in full sets... so you could go that route, try it half way through the swap process, and then decide if you want to continue.
    I am all for experimentation.... take pictures along the way!!
    Oklahoma City, OK
    2,690
    agree with Jimmie.
    If you wanted to do your mod, use your axle shaft(what you mount the wheel to), use summit/merv arms, half shafts and pushrod/toelinks. yes you would have to swap the end of your half shafts at the U-joint but thats a fast fix. same rockers, springs, buckles, pivots...yadda yadda.
    now you have MAD wheel base. then at a later point if you wanted a merv, put the merv axles back on, change rockers and springs, bumpers and body/bodymount and you could be in our club! hehe
    I want to see picutes too
    12,314
    Wheel base is the measurement from axle to axle.
    Track width is measurement from wheel to wheel on the same axle.
    You are going to "have MAD track width"
    120
    I did it to my slash and it was well worth it!! handles like a dream now!
    Oklahoma City, OK
    2,690
    I sit corrected, I knew it wasnt wheel base when I wrote it, but i was on a roll and I didnt want to think too hard, I have more important things (MERV upgrades to create) to waste on thinking about terminology...hehe
    pokin' at ya Jimmie...
    New Jersey
    259
    Well I ordered the parts this morning. Dont think i missed anything.
    Rpm Arms all Around,
    Half Shafts all around
    and stock rods.
    Only planning on doing the rear first. Bash on that a while then doing a full swap. Thanks everyone for your help. Will be posting picture of my slashenstein when all completed next week.
    12,314
    I don't correct to be mean... really.
    I usually assume that the person knows what they are saying, but it just came out wrong.
    I correct so when someone reads this... they don't get confused with incorrect terminology.
    So we don't get "Well, I read once that these Summit arms will make my MERV 10mm wider"
    -Which has actually happend.
    New Jersey
    259
    Just checked tracking this morning and my arms will be in when i get home from work. Its going to be a good day.
    On same note, just replaced my front bulkhead and stearing pin last nightand stupid me didnt just leave the thing stripped down, now i gotta do the process all over again. haha.
    Ill have pictures tomorrow.
    New Jersey
    259
    Well i swapped the rear out last night. Looks pretty cool. Ill be running it probably in an hour or so to put it through its paces.
    Heres what it looks like.
    Before the swap
    After the swap
    Ontario
    1,395
    that looks pretty cool, what kind of tires are those?
    New Jersey
    259
    Those are the Integy Type 2's I was telling you about in your tire thread.
    Ontario
    1,395
    Quote Originally Posted by Wileybrett View Post
    oh thats right, I decided I'm going to go with the pre assembled stock merv tires when I get tired of these.
    New Jersey
    259
    Ill be picking up a set of Merv tires as well. Sometime ill finish my merv conversion. Right now i like the look of a slash with a wide rear end. And its actually is 10x more stable now.
    Also, got me thinking of reversing the swap and placing my merv arms on the front and reswap my slash rear end. Same stability, mayber better steering?
    Ontario
    1,395
    probably.. that might look a little funny though
    New Jersey
    259
    Yea, very funny.
