Results 1 to 11 of 11
    Hong Kong
    65
    Smallest pinion for BB
    Hi, for 540 motor, may I know the smallest pinion can be used? I checked Brushed version Mini Summit, and the smallest stated in im is 16p. I wanna consider if can furhter gear down to 12p i
    so that I dont need to flip tran. Thank you for advice.
    Jul 2009
    Ontario, Canada
    11,286
    You can not get a 16t pinion on a titan 12t powered mini summit. I have one and the lowest I can hear is 23/55. Which isnt low enough for me. The reason is the motor will hit the rear shock mount bolts. A 540 size brushless motor may be short enough to clear the bolts bit I doubt you could gear any lower than about 18 or 19/55 at best.
    Feb 2007
    www.bumpsandjumpsrc.com Lewisberry,PA
    708
    I have a 19/55 on mine, but I am using a shorter motor(integy 55t) the trx 12t motor I think wouls be 20 or 21/55.
    Slash 4X4, Blitz ESE, Motocross, Mtn. Biking
    Hong Kong
    65
    Thank you for the information. I have the short can 540, and it is 4000kv which is same as stock 380vxl. It is too fast to me if running 3S. So I am looking to turn the power to better torque. In Brushed 1/16 Summit instruction manual, the gear chart shows 16/55 is possible, and if can further gear down, it will be perfect. If 19/55 is the max I can go, I will flip tran. Thank you and all of you are helpful !!!
    Jul 2009
    Ontario, Canada
    11,286
    I see absolutely no way to run a 16t pinion... I don't know why they would list that unless maybe its "hypothetical" gearing...
    Adelaide, South Australia
    31
    Hi all I really need some help with gearing, Ive read allot of info and have been getting lost in it all. I have a 1/16 summit with the vxl3s system but dont know what gears to use. I want it for crawling and climbing so speed dosent bother me. As it is atm the trans gear is stock 50t (if thats right) and I am going to flip the other trans gears around. I have a couple of gears of different sizes but the one I was thinking to use on the motor is a 31t ? Any help would be great.
    Feb 2002
    8,412
    stock gearing is fine if you plan to do the tranny flip for crawling... but your top speed is going to be very slow......
    TRUMP 16!
    31
    Thanks Jimbo, I have a 45 spur gear and a smaller pinion would it be worth putting those in aswell?
    31
    And how low a top speed would I be looking at with just trans flip?
    Feb 2002
    8,412
    Quote Originally Posted by d1noesis View Post
    like 20 mph, tops
    TRUMP 16!
    45
    20mph with tranny flip? that's hard to believe, it's faster than brushless?
