    Oct 2011
    212
    So I got a Velineon 3500 and...
    So I got a Velineon 3500 and the VXL3s esc. I was planning to use it in my brushed stamped but I got to thinking; "To big block or not to big block?" It seems that plenty of guys have done it. Is there a major con to this idea beside more broken parts? I would like to here some of your opinions on what you think.
    Alma, Michigan
    12,315
    This has been done before with that exact motor...
    Try searching so you can (hopefully) get a hold of the member that has done it.
    I toyed with the idea for quite a while, then decided not to.
    More than enough power can be extracted from a 380 sized motor.
    Jun 2010
    Miami, Fl
    6,731
    go for it, BB is great, I have done it, and itīs been great since.
    Brooklyn Park, MN
    1,249
    I coudn't even fathom more weight up high in a 1/16 slash. but in a summit, might be good.
    MM|2200kv 2WD LCG Slash - MM2|2650kv LCG Slash 4x4
    North Florida
    676
    true the 380 produces a ton of power, I just think it's undersized for the truck still... I always had heat issues with mine on stock gearing and 2s... only got worse when I geared it up, and I finally killed it with 25/45 gearing so it's sitting on a shelf beside me here and will be getting a BB swap in the near future, probably the current system in my Slash 4wd after I do a BB swap in it and put a 1/8th system in it, lol
