Page 1 of 13 12311 ... LastLast
Results 1 to 40 of 508
    Okanagan Valley B.C.
    750
    What did you break today?
    Broke a fin off my new ESC cooling fan and lost the screw from the esc/steering servo mount.
    I can't help but wonder if that was what broke the fin on the fan.
    18
    I don't think I broke anything but I opened my rear diff and found nothing but sludge, nothing leak or dripped out. Don't know if that is normal. I should probably check the front diff...
    750
    Quote Originally Posted by moody03svt View Post
    If you read your owners manual you'd see that the front dif is full of oil where the back is also full of oil but it is contained within the ring gear housing. The rear dif should have a modest coating of wheel bearing grease on the pinion and ring gear inside the rear dif housing.
    Traxxas writes such great manuals.
    18
    Thanks for info, I think. I will check over the manual again. Is the ring gear casing the same as the rear diff cover? I removed the cover which exposed the ring gears and there was grease all over inside but no fluid. Is the fluid inside where the large gear is still attached to the diff cover?
    Sorry to hijack thread!
    750
    Broke my first A-arm today and a shock cap.
    Good thing my lhs had a set of alloy caps in stock and the RPM arms I ordered will be in this weekend.
    Feb 2010
    El Sobrante, Ca
    9,287
    Yes it is in the black cup attached to the ring gear. It comes from the factory filled with grease but can also be filled with diff oil to tune it to your liking. If you want a more posi effect, go with a thicker oil. If you want more tight corners, go with a thinner oil or keep the grease.
    Slash Ultimate, ET-3S 2400 MIP King Headz RPM 3PL
    18
    No parts broken today but my friend broke some.
    750
    Ya just gotta laugh, even if they don't. . . .
    750
    Twisted the rear drive shafts out with the 3s LiPo yesterday, MIP's will be in this weekend.
    750
    Not sure what it is about my pede but the rear part of my bodies have been breaking easily and often, could have something to do with the 3s lipo and MIP induced cartwheels.
    750
    Ran 5 packs through her today in a fresh dusting of 2' of wet snow and at the end of it all I tried to right the vehicle by snapping it back and forth with the throttle breaking one of the front stub axle yolks. #6854x. Good thing my lhs had some in stock. Still gonna stick with the stock plastic stub axles in front and MIP's with HPI pins in the rear.
    All in all it was one heck of a good day thrashing my pede.
    750
    Broke another front stub axle today.
    Starting to think about MIP's for the front since I'm starting to like my 3s LiPo.
    17
    Broke a front A-arm yesterday and the day before that I broke a rear stub axle housing.
    Central Florida
    686
    Broke a front stub axle and a shock cap yesterday. Broke a MIP rear axle today. After a few speed runs and constant temp monitoring with a 3s I separated the magnet from the rotor in my stock velineon...
    Ipswich, Australia
    33
    I broke the part that comes out of the rear housing and the rear axles connect into them. I think its a rear stub axle? If I buy the MIP set does it also come with the stub axle? It sucks because no one in this city stocks traxxas parts! I have to order from amainhobbies.com good thing it only takes 4-6 days for my goods to arrive.
    Central Florida
    686
    MIP is a complete axle replacement stubs and all.
    Let my dad drive my pede today. He ran it into a curb and broke another front stub axle for me
    ERBE, Summit, Sl4sh MT, P4de, 1/16 GD 4x4
    Norway
    26
    Broke a little bit more off the body around the rear body holes
    So far that's the only breaking I'm doing to it..
    Stampede 4x4 VXL Pro-Line Trencher
    Dec 2006
    camillus, ny
    2,631
    I came up to the double and twisted the center of a rear rim apart at the track yesterday. I put my back up wheels and tires on then came off the double and landed in one of the boundary pipes and busted a c-hub and steering block.
    Man i need more than 50 characters.
    750
    Quote Originally Posted by Strykeviper View Post
    Had a "MY BAD" moment when I had my 3s in her and forgot to put my heat sink and fan on before running.
    Cooked the magnets in the motor but luckily I did have my fan on the ESC so at least it survived and my new motor should be in next weekend.
    What burns me is that I had the stuff with me in the pit box to prevent that from happening.
    750
    Quote Originally Posted by CoolKD View Post
    I've found that running a slash 4x4 rear bumper helps prevent some of the damage to the rear body posts and you can mount your wheelie bar wheels to them easily.
    Central Florida
    686
    Quote Originally Posted by NITR0 newbie View Post
    I had my heatsink on the motor but did not have the fan on
    Elyria, Ohio
    192
    Broke 2 rear drive shafts today....
    Central Florida
    686
    Bent a rear shock shaft
    Norway
    26
    Tanks for the tip
    Rotterdam
    54
    broke an rear driveshaft, mip's ready to install already
    Central Florida
    686
    Broke a front axle on the differential side. Also found a tear in one of my trenchers
    Central Florida
    686
    Broke a front axle again.
    First time I broke the front axle I bought one axle assembly and a pack of the stub axles. One stub axle left and I have a brand new set of MIP front axles waiting to go in the truck
    4
    Just got my truck yesterday. and i lost a body pin already.
    Broke the front axle on the first day. Bought MIPS for the front. Luckily, my LHS had the fronts in stock. They are heavy! Ordered the rear but won't swap that out until I break them. Got to use up the Traxxas parts first!
    Central Florida
    686
    Rounded out an aluminum wheel hex and it pretty much destroyed one of my desperados
    It was pretty funny to watch it flip and have the tire fly off at the same time though
    Central Florida
    686
    Broke a front stub axle. Later on broke another front axle.
    Finally out of spare Traxxas parts and have a set of MIP axles ready to go in :-)
    Dayton, Ohio
    40
    In the most epic fashion I ramped the very base of a small tree with the outside edge of my right tire.
    This then sent the truck into a leaping barrel roll. At which point you could see the right wheel Derp out wildly as the truck did a full barrel roll and landed back on the wheels.
    Initially it would appear as thought I busted the Tekno steering block only.
    Haven't broke anything in a while, and it was 100% worth it.
    17
    Broke an MIP rear axel!!! (the pin that holdes the CV together)
    this locked up the right rear wheel, sent me into a cartwheel
    and broke the wheelie bar
    replaced it with a stock axel
    and striped the stock motor
    it was a spectacular crash though
    Rotterdam
    54
    stripped a hex and wheel
    after fixing it that same wheel broke in half...
    also busted a outer bearing on the same wheel
    N. Salt Lake, UT
    40
    My pede slid sideways into a curb at near full 3s speed. Busted front bulk head, busted a steering link, and bent front and rear shock shafts on the left side. It also ripped my freshly painted lid. I run with Integy alloy arms, carriers, and shock towers. Those parts didn't bend or break. Other threads express so much dislike about Integy alloy but I'm here to tell you...they are strong. Expensive but strong.
    4
    my right rear shock is leaking.
    what do you guys think of the traxxas big bore shock kit, are they worth it?
    Dec 2006
    camillus, ny
    2,631
    I put the tin coated shafts from my big bores in my ultra shocks, and added aluminum caps. So far these work better than the big bores.
    Feb 2010
    El Sobrante, Ca
    9,287
    Big bores are.worth it! If people are breaking Mip axles, they are under warranty
    Central Florida
    686
    I think I burned a bearing in my 10 day old Velineon. Went to throttle after a rollover and heard a crunch like I had stripped a spur gear. I did strip the spur gear and after I got it changed I could not roll the truck. Took out the slipper clutch assembly and all I get is a whine and no movement out of the motor shaft. Can barely turn the pinion by hand.
    At least I have no downtime. I didn't want to wait when I separated the magnet on my original motor. Sent it in for replacement and bought a new one from the lhs. The new one from Traxxas came in today
    And the one I bought at the lhs is going out for replacement tomorrow
    Guess I was wrong about downtime. The seized velineon took my VXL-3S with it
    750
    Destroyed another Pro-Line body, that makes 5 now.
    At least my Slash rear bumper helped it to last a little longer and with the wheelie bar wheels on it, it seems a little more practical than the stock Stampede wheelie bar.
    Keep the comments coming guys and gals.
