Thread: Tranny Help
    98
    Question Tranny Help
    I was just out doing long distance high speed runs with my T-maxx. I have the old black tranny in it. The truck was originally a 2.5 but I put a 3.3 in it and beefed up the drivetrain a little. I noticed that when i did a high speed run in second gear, once i stopped and returned it to idle, and then took off again, the engine would rev high and then clunk into gear and take off. After it gets going its fine, it just hesitates before taking off. Could this be a problem with the spur gear? Is my old tranny just bad and I need a new grey one? And will this new grey tranny fit in my converted 2.5 to 3.3?
    THANKS!!!!
    -Off the Jump!!-
    CRASH
    Jan 2008
    Sugar Hill Ga.
    8,397
    I you still have reverse installed it could be the clutch pawl on the forward output gear not engaging the inner clutch bell until a high rpm. If you have forward only installed the one way bearing (OWB) inside the 1st gear primary could be slipping and then engaging the primary shaft at a high rpm.
    A good cleaning of either one and a drop of light oil on the pawl or OWB may help.
    98
    Ok thanks Ill try that. I have the forward only tranny
    -Off the Jump!!-
    CRASH
    98
    Do you by any chance have a diagram where this is labeled?
    -Off the Jump!!-
    CRASH
    castalia ohio
    5,602
    its probably in the downloads section man, try looking there. if nothing else it will have a part number and you can then look at the parts list.
    Drag It!
    Jun 2009
    Cocoa Florida
    4,896
    Follow Snooks advice, he is a transmission Genius
    Part #4997 gear w/shiny pawl if you still have reverse
    Part #4986 OWB
    Link to exploded view below::
    http://traxxas.com/sites/default/fil...ion-2008_0.pdf
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
    98
    Thanks!! I know about Snook. Ive heard the legends hahaha.
    -Off the Jump!!-
    CRASH
