Page 7 of 17 FirstFirst ... 56789 ... LastLast
Results 241 to 280 of 644
  1. #241
    Jan 2009
    Beautiful Downtown North Carolina
    1,449
    Quote Originally Posted by prsabordo View Post
    dyed wheels then clear coated them, replaced clutch shoes and spring. Then went bashing at a local track someone made.
    now thats what im talking about dirty revo,s!!!!!! Wooooohoooooo!
    Master of Traxxas engine longevity....
  2. #242
    Jan 2009
    1,449
    Well, almost ashamed to say, took off almost new engine just to break in another new one, noticed fins bent on head, just chalked it up to crash, and hitting something, noticed fins on new engine bent after saturday this week bash. Found out my Proline body wasnt cut out enough, and on rollovers it was bending fins...lol...so I just took my ziz wheel, and my trusty carbide burr, and cut out some more body, so i can keep straight fins! I know that isnt much, but I just wanted to add to this thread so bad I couldnt stand it!
  3. #243
    MIAMI FL
    152
    PIC OF THE RPM SENSOR MOUNTED
    TO MUCH TO LIST ON HERE
  4. #244
    Jan 2009
    1,449
    Quote Originally Posted by KTMRuss View Post
    I use 40t spur and a 15t clutch bell, and I get great low end power while still reaching about 45mph. All I do is bash, and this is the ratio I have use for the last 5 years. I think it's the perfect bashing combo.
    Dude, I love the 15/40 setup!
  5. #245
    Wake Forest, NC
    424
    Thx for the pics but either I need some glasses or they are out of focus. I will post what pics I have for my mine later tonight or tomorrow. It is In a great location but horrible for the telemetry RPM readings. They are way off because of gear ratio conversion. If i could figure out the math for MPH rollout conversion it would be perfect. Also, I have had to move the temp sensor 3 times. I think I finally have it in a good location. It is about 3 or 4 fins up from the top of the head screws. It is now reading within 4-5 degrees I think. Not sure I am totally liking this combo because I loose telemetry range in less than 200 feet or so. Also have lost range on the tx/rx because of the really short antenna lead.
    But I did run 5 tanks through her today with the new sway bars I installed a few days ago. WOW what a great difference. My under steer has been reduced by 70-80% easily. Seems to be running really well after the rebuild and break-in. Getting stronger and stronger each run. Running 30% O'Donnell Speed Blend. Smells funky and super oily, but has lots of power through the entire throttle band and and seems to run super cool. Stays around 230-240 at the most.
    Nitro-J-Rod
    Sent from my iPad using Tapatalk
    Nitro-J-Rod
  6. #246
    MIAMI FL
    152
    the sensor is actually focus onto the flywheel but like you say the accuracy is not the best
  7. #247
    Okanagan Valley B.C.
    760
    Put the 2.5r back in her and took her to the gravel pit.
    Nice day,about 50f, Ran a couple tanks through her.
    Sometimes that motor is like beating a dead horse though.
    Runs great for the first tank and then gets little weird on the second tank.
    No low end punch, high temp's an fuel on my rear shocks.
    Thrashed on my Stampede with a 3s till I snapped the yolk on the front stub axle.
    Buy this time the revo cooled down enough for the same tank and a half routine again.
    When I got home I threw the 3.3 back in her since that motor runs great and had a closer look at my 2.5r.
    Turns out when I rebuilt that motor I should have used a new shim instead of the old one and there's a good chance that I didn't torgue the cooling head bolts right.
    I have to admitte that it has been a very sharp learning curve with nitro's and rc's in general.
  8. #248
    Kauttua city, Finland
    197
    I bought a bag what I'm gonna use to carry my revo. Now I'm going to check that it really fits in there Might post some pics, but first I need a complete revo, not just millions of parts on some desk
    |Traxxas|Revo|3.3|#5309|FIN|
  9. #249
    11,763
    Quote Originally Posted by NITR0 newbie View Post
    Check the exhaust header as it comes out of the engine. They can split right at the weld or have a split along the outside bend and it will leave residue on the rear shocks.
  10. #250
    760
    New header and it was the first thing I checked, what lead me to the shim was the fuel all over the inboard side of the motor from the cooling head down.
    So you think I should re-install the head shim and be a little more careful torquing it or just get a new shim G?
  11. #251
    11,763
    I've never had issues with reusing a shim. Torque it like an auto wheel: in a star pattern. But they are only a few bucks so a new one would be a good idea if you still have problems.
  12. #252
    760
    Thanks G.
    I'm guessing since I re-built this motor when I bought my first rc (4 months ago) that I may have torqued the head wrong is all.
    Hope I didn't fry the motor lol.
    Seems like it still has good compression so what the heck eh?
  13. #253
    65
    Ordered a new Carb, P2 rockers, and a pull start off eBay!
  14. #254
    Plano, tx
    239
    Pulled the motor down after a very hot run Sunday. Will be picking up new piston and sleeve tomorrow and start the breaking and tunning process again. Expensive lesson learned to check the bottom side of exhaust boot for cracks and inspect the fuel tank more closely. Those two small items cost me a motor by not providing enough fuel back pressure at high speeds.
    Has anyone ever had this happen? Any upgrade parts suggestions to prevent again or just better after run procedure?
    Warned to not use symbols..........
  15. #255
    69
    Hello everyone I am going to purchase a Traxxas Nitro truck but I need some help to choose, I am debating on the T-Maxx 3.3 or the Revo 3.3 and witch truck is a bigger truck and faster and handles good on turns ???
    Thanks Steve
  16. #256
    Dirty jerzey
    81
    My buddy has a revo 3.3 its a beast but if u ask me i would get a LOSI LST XXL. The best 4x4 on the market i think.
  17. #257
    Plano, tx
    239
    After last weekends nuclear melt down run, took the Revo down to bare frame. Rebuilt engine, new front bulkhead, changed all the diff oils (300 front, 500 center, 100 rear), Motor Saver air filter, new clutch, went through trans, rebuilt shocks, new ez-start wiring and one way (again), re-set all suspension settings, and getting ready to head north for the weekend with it.
  18. #258
    65
    Today she got a new Carb, P2 rockers, and a pull start. Tightened up my pillow balls and threw my camber and toe settings WAAAY out of whack lol.
  19. #259
    11,763
    Those are pretty thick fluids for the diffs. I run 50k/30k.
    Since the sleeve was repinched, I figured I'd put the roto-start back on to ease with starting for break-in. Also ran some chapstick on the pull-start string to lube it up. We'll see if that prolongs its life or not.
    Brought my Revo upstairs without the body and now my 2 year old is pushing it around with a pile of his Matchbox cars on it--trying to fit as much as he can but most keep falling off.
  20. #260
    Plano, tx
    239
    50 center 30 front 10 rear.
  21. #261
    760
    Took all three of them out to the gravel pit and thrashed the heck out of them.
    Finally got the 2.5r running like it should, reused the same shim on the head thanx to G's advice.
    Can't wait to convert the 2 new ones to the 2.4 set up, seems to make the rx bat last longer.
    GO REVO's ! ! ! !
  22. #262
    wisconsin
    230
    lowered my revo down a bit and put some new tire's on to go with the new THS BB rear pipe
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
  23. #263
    Apr 2007
    SO Cal O.C.
    47
    Picked it up, looked outside at the rain and darkness. Then sat down, rolled it on the table to check if it had a center diff.
    Signing off from
    Left of Area 51.
  24. #264
    65
    Quote Originally Posted by DJ View Post
    [IMG][/IMG]
    Looks like your fuel tank is hooked up wrong?
  25. #265
    11,763
    He's right!
    Good eye.
  26. #266
    760
    Took her out the gravel pit and thrashed her good for about 1 1/2 hrs till I broke another header.
    Got me thinking it's time to switch to a spring held header.
    Good thing she's got backup.
  27. #267
    Wake Forest, NC
    424
    He's right!
    Good eye.
    I think it is an optical illusion, one of the earlier pics shows it properly positioned.
    Nitro-J-Rod
  28. #268
    11,763
    Quote Originally Posted by jarod_rodriguez View Post
    Follow the hose from the pipe and it goes to the outlet of the tank and the tank pressure port is hooked up to the carb.
    That engine is not going to run.
  29. #269
    Wake Forest, NC
    424
    Crude. Wasn't looking at that. LOL.
    Nitro-J-Rod
    Nitro-J-Rod
  30. #270
    wisconsin
    230
    Good eye I did hook it up wrong after taking engine out for interal inspection and installing the new pipe
  31. #271
    Plano, tx
    239
    After much study and advice from a forum icon (you know who you are)......PICCO Maxx .26, ERCM pipe, Buku clutch, techno RC box, throttle servo mount, throttle linkage, and fuel tank mod. Can't wait for Friday when everything arrives.....Christmas in March!!!! Will be up late Friday installing all the goodies!!! FYI: the 3.3 I modded the mount tonight and fit it into an old HPI Super Nitro RS4.......outta be an interesting test drive tomorrow!
  32. #272
    wisconsin
    230
    Quote Originally Posted by Revo gene View Post
    Sounds like a great set up ,be lookin forward to seeing some pic's
  33. #273
    Wake Forest, NC
    424
    I think I smoked reverse. Tons of smoke came off the truck today and it no longer moves when engaged. Err....
    Nitro-J-Rod
    Nitro-J-Rod
  34. #274
    760
    Sold one of my 2.5r revo's today for twice what I paid for it.
    Think I'll dump the funds into the newer 3.3 that I bought, maybe try the street speed set up just for giggles.
  35. #275
    36
    Just rebuilt my engine with a new piston and sleeve... Also, just installed a 3 piece clutch kit. Now i gotta get a good day to break it in...
    Sent from my Inspire 4G using Tapatalk
  36. #276
    wisconsin
    230
    up date on my fuel line's
    [IMG][/IMG]
    [IMG][/IMG]
  37. #277
    78
    Haven't been able to run the truck lately. Took it to the lhs for a quick tune session to see what I did wrong and apparently my engine bearings were going bad. Gritty and just not smooth. Didn't seem bad enough to cause issues but we took the motor apart and I put it back together. Didn't get much time to test it because it was late. Making a whirly noise so I am unsure why.
    Sent from my DROID RAZR using Tapatalk
  38. #278
    NY
    53
    I took some time to break-in the 3.3 today and all is good. Tomorrow I will start laying into it for some good old bashing...
    Summit, Slash 4x4 Platinum, Revo 3.3, T-MaxxPro-15
  39. #279
    Simi Valley, CA
    499
    Ran many tanks through and covered the Revo in dirt! Good times!
  40. #280
    wisconsin
    230
    Quote Originally Posted by Jake C6R View Post
    you must clean her up and regrease all bearing's LOL ,My revo is street bashing only I leave the dirt for the XL and MGT 8.0
