Results 1 to 16 of 16
    Nov 2011
    46
    Question about 3S LIPO 1400MAH for 1/16 EREVO VXL
    Hey im getting my 1/16 EREVO BRUSHLESS in a few days and i want to get two(2) 3S lipos! Im pretty sure i need a series connector but is there anything else i need to know or get? And what charger do i need, id prefer one made by traxxas, do they sell any lipo chargers?
    19,426
    Quote Originally Posted by robwit View Post
    1/16 E-Revo BL will not handle two (2) 3S LiPos in series (= 6S). It is not rated for two (2) 2S LiPos in series (= 4S) either. A parallel adapter will double your run time but not your voltage.
    The announced Traxxas multi-chemistry charger
    (TRA2933 EZ-Peak Plus 6-Amp Lipo/NiMH Battery Charger)
    has not been introduced to market yet.
    Alt-248 on the number pad =
    Nov 2011
    46
    Thanks im thinking about just running 2 2S Lipos (= 4S) or just one 3S Lipo. What do you think?
    And that charger is pretty cool looking any idea when it will come out or how much it will be?
    UK
    1,936
    look there are two different types of connector to run 2 batteries. One is the series connector this in effect joins your two batteries up creating double power/voltage. you CANNOT use this connector on Li-Po batteries as say you wanted to run 2 2s. well 2s + 2s = 4s and the esc can only take 3s so no. However the other connector is the parallel connector this gives you twice as much run time but same speed (in theory) it's like adding an identical extra fuel tank to a full sized car it'll give you twice the run time. IMO you should start with a 2s lipo as this will give you a higher top end but will still be controllable and wear parts out slower. If you want very high run times get 2 2s packs of identical spec and manufacturer and get a parallel connector otherwise stick with a single battery
    Does more $ = More fun?
    Rustler VXL
    19,426
    Right now estimates are middle of November to early December and under $100.
    muscoda, wi
    1,245
    charger on ebay for 88 bucks. utube has videos runnin 2-2s lipos in series. dont believe me. believe the videos.
    California
    4,840
    stormerhobbies has the new traxxas lipo charger for 77.99 i think give a look i might be getting that.
    DEU 8:18 ESV
    12
    I have ran mine on 2-2S in series. You have to disable the voltage detector. I wouldnt recomend this. I ran it a little to long and balloned one of my batterie. You also run a high risk of smoking your motor or esc.
    California
    4,840
    follow the ratings on the esc and motor on all your rc's and you'll be just fine, if it burns out on a traxxas product follow their ratings then give them a call and see what they will help you out with. but disabling the voltage detector was a bad idea from the start. you were lucky it didnt catch fire doing that.
    DEU 8:18 ESV
    Feb 2013
    36
    Make sure your esc is on lipo low voltage section mode because it can kill the lipos battery life.
    I have the ken block vxl with the 380 with a lipo so ya.
    Alma, Michigan
    12,314
    The thread is a year old...
    Oct 2012
    28
    it may be but i want to know if the guy didn't take people's advice and blew his erevo.
    Alma, Michigan
    12,314
    The OP has not been online here at the forums since 01-02-2012 01:24 PM.
    Dec 2015
    4
    Do you recommend Maxamps 3s 9.9v 1050mah 45c batteries instead of a normal 11.1v 3s?
    Alma, Michigan
    12,314
    I do not recommend anything from MaxAmps.
    Sep 2011
    Iowa City, Iowa, USA
    4,244
    Lol. This thread won't die. It's 4 years old now.
