    Jun 2011
    13
    Put in New servo and steering is reversed
    As the title says I got a new Hi-Tech Servo. I installed it and for some reason when I turn the wheel on the controller to make it steer right and its steers left.
    I have made sure that the servo is installed properly.
    Any help would be great!!
    Thanks
    Sep 2011
    8
    i just ran into the same problem. all you have to do is hit the switch on the bottom of your transmitter for reverse steering and all should be good
    11,660
    With the AM radio, it is that simple. With the 2.4, you'll have to go through the menu to switch. That menu is in your manual.
    Jul 2009
    Central Cali
    259
    Yeah what is the deal with that??? I have run into the same problems with certin servos when I change them out???
    What causes this G?
    Matt
    This is getting expensive!!!!!!
    Sep 2011
    georgia
    164
    Depending on the manufacturer of your servo the wiring for the receiver could be opposite of the traxxas but as the other guys said its an easy fix
    Jun 2011
    13
    yes Chadillac you are right. Depending on manufacturer, ther servos will come pre reversed for planes and boats. so therefore you must adjsut this setting through your controller. I had to call the maufacturer for this.
    thanks everyone for your help it is greatly appreciated.
    Troy
