    Jan 2009
    63
    Slash rishless battery question
    Not sure where to post this...
    but it is for 2 slash trucks with velineon sustems and I have questions about the battery charging
    I have 2 - 5250mah, 60C 2s packs
    they charged on an onyx 230 (does lipo) charger
    setting charge to 5amp (knowing it can charge at 1C rate of 5.2
    auto shut off on charger at 124 minutes.
    1 pack charged 40 minutes and showed only 2500mah
    the other charged 85 minutes and showed about 5000 MaH.
    This is the charge the Onyx recorded as "supplying"
    they were both discharged to about 3.2 MaH (just a tad higher than 3.2)
    anyhow...shouldn't they have both charged the same amount? time and total?
    does the onyx read only input? and if so when it stops before the time alotted for charge does it just sense that the battery was full?
    1 pack shows 1 cell at 4.2 V and the other at 4.21V
    the other pack shows 4.21 and 4.19
    is that acceptable levels?
    Thanks in advance
    You don't know what you don't know.
    13,773
    Did you call the manufacturer?
    Ya can't polish fertilizer...
    Springfield, MO
    3,679
    Put them in truck, go drive, does it last 30-40 minutes?
    19,423
    Please contact the manufacturer for aftermarket item SUPPORT.
    Alt-248 on the number pad =
